SpyGlass3 USB board 810067 SATA wires soldering points
fastec
Postby fastec » 22.10.23, 11:59
do any of you can gently share a picture of the soldering points for the SATA wires?
Thank you
FAsTec is the owner of the Italian popular brand RecuperoDati299
https://www.RecuperoDati299euro.it
fastec
Re: SpyGlass3 USB board 810067 SATA wires soldering points
Postby fastec » 22.10.23, 13:27
OK
converted see attachment
WD 810035 810067.pdf
(2.82 MiB) Downloaded 467 times
fastec
Postby fastec » 22.10.23, 18:39
Ok
case solved
case arrived open with wrong heads installed ruined by some "improvised-data-recovery-shop" using some poor heads separator that damaged in the same manner the same head in the same point , both the original heads and the wrong donor heads we received installed in the drive.
what is worse for the customer (under the costs aspect) is that ... probably the original heads were good and it was just matter of usual WD restoring processes ...
for you to know, easy to guess, since SpyGlass2 Ultra and SpyGlass3 do share the same SATA board, if you don't have the latest PC-3000 , it will work using SpyGlass2 Ultra utility
Return to “WD USB”
