Sandisk 20-82-00369-282
Typical Flash recovery cases
jerema
Postby jerema » 23.01.18, 13:22
I got usb stick with Sandisk 20-82-00369-282 with one chip 32GB
Did anybody know, if this chip is encrypted ?
Re: Sandisk 20-82-00369-282
Postby Roman_TS » 23.01.18, 13:25
Most of modern Sandisk controllers does not use encryption. Only XOR.
jerema
Postby jerema » 23.01.18, 13:48
Ok, thanks Roman, then I will desolder the chip and try to solve with pc3000.
jerema
Postby jerema » 25.01.18, 19:29
Unfortunately it is a LGA60 chip.
Postby Roman_TS » 26.01.18, 08:13
jerema wrote:Source of the post Unfortunately it is a LGA60 chip.
You can read it with TLGA-52 adapter. Additional 8 pins are not critical for chip reading.
jerema
Postby jerema » 26.01.18, 10:03
Hello Roman,
this does not work. There comes a message: PWR ON Error on Channel VCC. ...uncompatible power scheme
Postby Roman_TS » 26.01.18, 14:43
Try to chose power scheme ID=1785 during chip ID reading. Should help.
jerema
Postby jerema » 26.01.18, 16:13
I can not found this power scheme
Postby Roman_TS » 29.01.18, 08:08
Here is it:
MasterT
Postby MasterT » 05.04.18, 15:01
I also have an LGA60 Chip H23QFG8PG1MCS Manufacturer SK HYNIX.
I tried to read using power scheme ID=1785 with TLGA-52 adapter, chip is centered, clean contacts.
I get the following error.
Postby AJ2008 » 05.04.18, 16:28
Does it display ID correctly, and all looks good, then this error is presented?
I see these symptoms I describe before and could not read in PC3000 reader, I had to use other reader to get dump made, I do not know why this happens, hopefully is some simple solution that Acelab can tell us all :)
Postby Roman_TS » 06.04.18, 08:43
MasterT wrote:Source of the post
A couple of questions:
1. Do you see chip ID in Log?
2. Are you sure that your chip LGA-60?
3. Did you turned off all other reading schemes like on my screen?
download/file.php?id=1025&mode=view
MasterT
Postby MasterT » 11.04.18, 11:58
1. I cannot see chip ID.
2. i attached a picture for confirmation.
3. I did exactly as in your picture.
MasterT
Postby MasterT » 14.04.18, 08:25
Most likely chip is dead.
Multi-COM
Postby Multi-COM » 20.04.18, 21:45
Is this H2JTDG2MBR ? If answer is Yes then its probably not death.
Boguslaw Rzepka
http://multi-com.eu
Users browsing this forum: Baidu [Spider] and 1 guest
