I got usb stick with Sandisk 20-82-00369-282 with one chip 32GB
Did anybody know, if this chip is encrypted ?
Re: Sandisk 20-82-00369-282
Most of modern Sandisk controllers does not use encryption. Only XOR.
Ok, thanks Roman, then I will desolder the chip and try to solve with pc3000.
Unfortunately it is a LGA60 chip.
jerema wrote:Source of the post Unfortunately it is a LGA60 chip.
You can read it with TLGA-52 adapter. Additional 8 pins are not critical for chip reading.
Hello Roman,
this does not work. There comes a message: PWR ON Error on Channel VCC. ...uncompatible power scheme
Try to chose power scheme ID=1785 during chip ID reading. Should help.
I can not found this power scheme
Here is it:
I also have an LGA60 Chip H23QFG8PG1MCS Manufacturer SK HYNIX.
I tried to read using power scheme ID=1785 with TLGA-52 adapter, chip is centered, clean contacts.
I get the following error.
- Attachments
- error.png (7.72 KiB) Viewed 25456 times
Does it display ID correctly, and all looks good, then this error is presented?
I see these symptoms I describe before and could not read in PC3000 reader, I had to use other reader to get dump made, I do not know why this happens, hopefully is some simple solution that Acelab can tell us all
MasterT wrote:Source of the post
A couple of questions:
1. Do you see chip ID in Log?
2. Are you sure that your chip LGA-60?
3. Did you turned off all other reading schemes like on my screen?
download/file.php?id=1025&mode=view
1. I cannot see chip ID.
2. i attached a picture for confirmation.
3. I did exactly as in your picture.
Most likely chip is dead.
Is this H2JTDG2MBR ? If answer is Yes then its probably not death.
Users browsing this forum: Baidu [Spider] and 1 guest
