771754 - 701692 or 771692
In my case it does not match. I have 771754 PCB with a 512kb Rom and 771692-005 works with 256kb Rom.
Who knows which Code is needed to get 512kb PCB (compatible with 771754) ??
List of compatible SATA PCB for 2,5" USB drives
Re: List of compatible SATA PCB for 2,5" USB drives
771692 is the correct number. You'll just have to find the right revision board which has that size ROM. Try a -005 REV A, I think that's the one I most commonly use.
DataMedics wrote:You can connect to a computer too, as long as you isolate the preamp so only the motor is spinning, then read ROM through terminal. Or just use boot ROM code. Always works for me.
Me too
What model of the HD that comes with the 701672 board?
Can you help me please
Wanderson wrote:Source of the post What model of the HD that comes with the 701672 board?
Why ask what you can just search in 2 seconds on ebay?
http://www.ebay.com/sch/i.html?_odkw=70 ... b&_sacat=0
i tested 771.962 - 771.959 not working
Help me
Help me
Data recovery Center in Vietnam
Invited to visit : http://www.cuudulieu116.com
My Facebook is : https://www.facebook.com/cuudulieuocung
Just a few questions. First off, did you swap out the ROM code? Also, are you sure there isn't a bigger issue with the drive such as failed heads? Also, are you getting a message such as "SED locked" when you try to load the utility?
The boards are compatible. So it must be something else you're missing.
DataMedics wrote:Source of the post Just a few questions. First off, did you swap out the ROM code? Also, are you sure there isn't a bigger issue with the drive such as failed heads? Also, are you getting a message such as "SED locked" when you try to load the utility?
Yes me have transfer u12
But it does not work
Can not open power motor not spin up
help me
Did you transfer it correctly? The right side?
jenny, please show us the photo of U12 chip on board
800067-800065
shihzur, thank you, added into the list!
In case anyone is interested, for the past several months I've been using a new method for converting USB to SATA. I organize all my SATA PCBs by CPU numbers (i.e. "9446") and, if applicable, ROM size (i.e. 256/512), PCB shape, and MCU(?) type (either SH or NAUT). I think there are about 20 variations for all WD USB PCBs. Second, I read USB ROM using BootRom so I can instantly see the CPU model. Then I just match any remaining variables (ROM size, PCB shape, MCU). This works 95% of the time. The other 5% that don't work after this typically requires physically moving the ROM chip from original PCB to donor (I wanna say this is just for some 9146 models, but I may be remembering incorrectly).
Any suggestions for this drive?
Model: wd20smzm-59h3fs1
USB C PCB: 2060-810003-001
lcoughey, we didn't see such drives here in support.. Have you tried to solder SATA adapter to see if the drive allows to read SA?
