I have the following error on this 500gb drive:
FlashLED - Failure Code:000000cc Failure Address:0024a50d
Am I right in trying to repair using the HDD Lock(LED:000000cc) solution?
Seagate ES.2 000000cc problem Topic is solved
Re: Seagate ES.2 000000cc problem Topic is solved
Because it is ES.2 you will need to short circuit the read channels - it is probably not possible to get T> from PCB alone on this model.
What is FW on drive label?
Bad Translator. Short read channel, clear smart, regenerate translator, image data.
FW is SN04
Same as classic SD15 fix?DataMedics wrote:Source of the post Bad Translator. Short read channel, clear smart, regenerate translator, image data.
SD15 will give T> on PCB alone allowing the option to spindown and reattach HDD. SN04 and most ES.2 will not allow this, so only way to reach terminal is to short circuit. Once shorted T> will be present and original steps can then be followed.
