Seagate ES.2 000000cc problem Topic is solved
gbulger
Postby gbulger » 07.07.16, 14:02
I have the following error on this 500gb drive:
FlashLED - Failure Code:000000cc Failure Address:0024a50d
Am I right in trying to repair using the HDD Lock(LED:000000cc) solution?
Re: Seagate ES.2 000000cc problem  Topic is solved
Postby AJ2008 » 07.07.16, 15:03
Because it is ES.2 you will need to short circuit the read channels - it is probably not possible to get T> from PCB alone on this model.
What is FW on drive label?
Postby DataMedics » 07.07.16, 22:53
Bad Translator. Short read channel, clear smart, regenerate translator, image data. :D
gbulger
Postby gbulger » 08.07.16, 14:26
FW is SN04
gbulger
Postby gbulger » 08.07.16, 14:28
DataMedics wrote:Source of the post Bad Translator. Short read channel, clear smart, regenerate translator, image data. :D
Same as classic SD15 fix?
Postby AJ2008 » 08.07.16, 16:48
SD15 will give T> on PCB alone allowing the option to spindown and reattach HDD. SN04 and most ES.2 will not allow this, so only way to reach terminal is to short circuit. Once shorted T> will be present and original steps can then be followed.
Users browsing this forum: Bing [Bot] and 12 guests
