PM851 Samsung need pin Tx and Receive pin
jinarto
Postby jinarto » 16.01.16, 11:26
hello all,
where i can connect RxD and TxD signal for terminal on Samsung MZ7TE512HMHP 2.5" SATA PM851 Family ?
Thanks :D ,
Jinarto
Re: PM851 Samsung need pin Tx and Receive pin
Postby Roman_TS » 16.01.16, 11:34
Hello! Those two pins in the top of the board are the pins for terminal connection.
jinarto
Postby jinarto » 17.01.16, 08:18
yes Mr. Roman.
which is TX and which is Rx pin ?
i show you in this attachment pic. if i wrong please correction. ok ?
Thanks :D ,
Jinarto
Postby Roman_TS » 18.01.16, 10:27
Need to check it by yourself. Try both combinations. In Samsung Utility, should be a picture with correct PIN placement.
jinarto
Postby jinarto » 18.01.16, 17:48
hi Mr. Roman,
it need to check it by myself about which TX and which is Receive side ? how if i wrong rx and tx side. what happen if wrong side?
Thanks :D ,
Jinarto
Postby Roman_TS » 18.01.16, 17:59
Nothing will happend. If you will connect terminal wrongly - SSD will not detect terminal.
Postby Roman_TS » 19.01.16, 15:20
Case is recovered in ACE Lab TS :)
jinarto
Postby jinarto » 21.01.16, 05:09
hello Mr. Roman.
o yes, thanks very much for you and for your good tool to recover this case.
another problem. how to low level format this pm851 ?
in terminal appear these :
Selected family......................... : Samsung 840 EVO series
Controller.............................. : S4LN045X01-8030
Techno mode key......................... : Techno mode error; unexpected error: Device error detected - Device error detected - Device error detected - Device error detected
SSD status:
Loader uploaded......................... : No
Loader uploading
Code name............................... : 840EVO.ldr
Write HDD microcode
Waiting 2 sec.
Write Main Firmware..................... : Ok
SSD status:
Loader uploaded......................... : Yes
Reading password information............ : Ok
Command execution is not possible because of logical access is not available!
i have been plug Tx and Rx.
Thanks :D ,
Jinarto
Postby Roman_TS » 21.01.16, 09:54
Firmware update with _FORMAT option will allow to erase all user data and restore SA to default settings.
jinarto
Postby jinarto » 24.01.16, 11:32
Yes. You r right. you make this ssd pm851 be new again. thx alot for you and pc-3000 ssd
Thanks :D ,
Jinarto
thientankt
Postby thientankt » 28.08.16, 12:33
hi Roman
can't find menu FW update menu (just reading and writing in FW menu)
can't clear pass
tks
Thien Tan Data Recovery in Viet Nam
167 Tan Phuoc St 6 Ward, 10 Dist
Tel: (84)907 23 24 62
Skype/yahoo: thientankt
www.cuudulieuhcm.com |www.cuudulieuserver.net | www.phuchoidulieu.net
Postby Roman_TS » 29.08.16, 17:40
Hello. About all technical questions better create ticket in our TS department. Thanks :)
Postby Amarbir[CDR-Labs] » 01.09.16, 13:43
jinarto wrote:Source of the post hi Mr. Roman,
Roman ,
It Was Me Who Motivated To Update His Pc 3000 ,I Now Have 5 People In My Kitty Whome i Have Refered And they Have Purchased New or update there pc 3000 tools
Return to “Other SSD Samsung”
