hello all,
where i can connect RxD and TxD signal for terminal on Samsung MZ7TE512HMHP 2.5" SATA PM851 Family ?
PM851 Samsung need pin Tx and Receive pin
Re: PM851 Samsung need pin Tx and Receive pin
Hello! Those two pins in the top of the board are the pins for terminal connection.
yes Mr. Roman.
which is TX and which is Rx pin ?
i show you in this attachment pic. if i wrong please correction. ok ?
Jinarto
Jinarto
Need to check it by yourself. Try both combinations. In Samsung Utility, should be a picture with correct PIN placement.
hi Mr. Roman,
it need to check it by myself about which TX and which is Receive side ? how if i wrong rx and tx side. what happen if wrong side?
Jinarto
Jinarto
Nothing will happend. If you will connect terminal wrongly - SSD will not detect terminal.
Case is recovered in ACE Lab TS
hello Mr. Roman.
o yes, thanks very much for you and for your good tool to recover this case.
another problem. how to low level format this pm851 ?
in terminal appear these :
Selected family......................... : Samsung 840 EVO series
Controller.............................. : S4LN045X01-8030
Techno mode key......................... : Techno mode error; unexpected error: Device error detected - Device error detected - Device error detected - Device error detected
SSD status:
Loader uploaded......................... : No
Loader uploading
Code name............................... : 840EVO.ldr
Write HDD microcode
Waiting 2 sec.
Write Main Firmware..................... : Ok
SSD status:
Loader uploaded......................... : Yes
Reading password information............ : Ok
Command execution is not possible because of logical access is not available!
i have been plug Tx and Rx.
SSD status:
Loader uploading
Write HDD microcode
Waiting 2 sec.
SSD status:
Jinarto
Jinarto
Firmware update with _FORMAT option will allow to erase all user data and restore SA to default settings.
Yes. You r right. you make this ssd pm851 be new again. thx alot for you and pc-3000 ssd
Jinarto
Jinarto
- thientankt
hi Roman
can't find menu FW update menu (just reading and writing in FW menu)
can't clear pass
tks
can't clear pass
tks
Thien Tan Data Recovery in Viet Nam
167 Tan Phuoc St 6 Ward, 10 Dist
Tel: (84)907 23 24 62
Skype/yahoo: thientankt
www.cuudulieuhcm.com |www.cuudulieuserver.net | www.phuchoidulieu.net
Hello. About all technical questions better create ticket in our TS department. Thanks
jinarto wrote:Source of the post hi Mr. Roman,
Roman ,
It Was Me Who Motivated To Update His Pc 3000 ,I Now Have 5 People In My Kitty Whome i Have Refered And they Have Purchased New or update there pc 3000 tools
