hi to every one
could someone please tell me how shall i connect the usb terminal on a sata toshiba because i am gettins some errors! or if there are some updates which i have to install them?
toshiba info
Re: toshiba info
Why do you need to connect the usb terminal to Toshiba drive?
Re: toshiba info
toshiba doesnt has terminal log from startup like Seagate until im know
Re: toshiba info
there is a terminal access for Toshiba. But it is not so important
Re: toshiba info
Please supply terminal connection layout for Toshba SATA drives.
Re: toshiba info
I also require the toshiba SATA terminal connection layout. You do need to connect terminal to allow capture of the CP modules?
Joel
Joel
Re: toshiba info
Found a diagram on another forum.. Worked well..
- Attachments
- pins.GIF (3.09 KiB) Viewed 10131 times
Re: toshiba info
Is the ground pin required? On the deepspar forum they only show the txd/rxd connected.
Re: toshiba info
You need only TX and RX attached to the middle jumper pins.
At terminal window hit "Enter" you should see a ">" sign if terminal is correctly attached.
IF not, switch positions of TX + RX connections.
