Seagate 2tb EB1
NSRGroup
Seagate 2tb EB1
Postby NSRGroup » 10.06.25, 11:17
Hi guys,
i have a hdd seagate 2tb 2.5" with fw EB1
i pached rom after rewrite rom in utility
and Run utility
Software can`t control COM port signal level for this USB/COM adapter
Family ID by HDD ID: AF
Selected Family ID: AF
Selected family......................... : AF, Rosewood_AF
Model by ID............................. : ST2000LM007-1R8174
Tech Key...
Requesting FW Pkg ver ........ R1AEA069E.SDM4.650003.EB01
Detecting SA Phys Sct Size...
Result.................................. : 4096
Detecting UA Phys Sct Size...
Detecting Max Head number...
Phys. heads............................. : 4
Reading Saved Mode Pages...
Parsing Saved Mode Pages...
Media Cache
MC : disabled
MC Size : 0x0
MC MCMT Ver is unavailable!!!
ID Len
0 40 Reserved Defect Table (SA defect table)
1 8 Drive Information File (DIF)
3 7800 Primary Defect File (P-List)
5 8 Manufacturing Information File (MIF)
8 4800
B 1000
C 122880 Serial Port Test Results File (Self Scan Log)
D 160
F 224 DIC Dummy File
15 128 BGMS File (Directed Offline Scan)
16 8
17 40
19 32 Log File
1A 40 Log File
1B 8 Log File
1C 16
20 384 Physical Overlay File 3
21 256 Physical Overlay File 4
2A 16 Saved Mode Pages (HDD settings)
2B 2008 R/W Operating Parameters (translator, etc)
33 4576
37 6800
3A 8
3C 616
3D 3584 Disc firmware container 1
3E 3584 Disc firmware container 2
3F 4576 SED parameters
40 184 SED parameters
41 2184 SED parameters
42 4096 ST Ovl
43 5128 Defect list report file
44 2240120 BIG file
45 1785856 BIG file
46 302752 BIG file
47 142368 BIG file
48 592 BIG file
49 232 BIG file
4A 8320 BIG file
4B 4352
4F 8192
50 30560 MCMT
52 8
58 12800
5C 2048
Collecting DT Infos...
ROM:
ID MemOffs Len
0 80400000 230400 Read Adaptive Parameters File (RAP)
1 80439400 512 Controller Adaptive Parameters File (CAP)
4 118B00 8192 Servo Adaptive Parameter File (SAP)
80000000 16
total 8208
A 475BF4 1024 Seek Profile
13 80459CD8 2448 Dependent Zone Table for User Area
14 8045F670 32 Dependent Zone Table for System Area
15 0 1048576 Flash ROM
1D 80400020 5000 VBAR Configuration File
1E 804028A8 9680 Zone Format Parameters File
26 80452E28 28336
27 80452D08 288
RAM:
ID MemOffs Len
2 804013A8 4832 Zone Table
80000000 16
total 8208
6 19D44E0 81940 Servo Flaw Table
16 80400000 32 Drive Configuration Table
17 804061A8 4848 Temperature Control Configuration
1F 80840B80 17136 RW working user preamp table
20 80844E70 112 RW working system preamp table
22 81638000 692224
25 816E1000 315392
26 80452E28 28336
27 80452D08 288
28 815E5000 327680
39 80D6DB80 2228224
3E 8045C1F0 13440
3F 8045F690 480
40 8045A730 6848
41 80402688 544
43 8045A668 200
4A 8172E000 8192
Collecting DT Infos completed
System Files I/O method detection... ATA(direct)
Error executing command "En Tech" (TIMEOUT)
Drive power supply...................... : OFF
and in terminal
Rst0x80M
FTU
TCC:001A:0025 EMCDataErr:00000012
PrgF
(P)SATAReset
RAWOFF
PASS
Bothcopyissame!Out:Out:
DSC PASSOut:Out:
PrgF
6GbMaxSpeedloweredto3GbforIntelbug
SendStatus:COMRESETseen
CSpd=3Gbps
FIS34
I can read modules but terminal do'nt work correctely
example
F3 T>
ASCII Diag mode
F3 T>/7
F3 7>X
didn't answere anything or after
F3 T>
ASCII Diag mode
F3 T>V1
XI2
WARNING!!! LBA remapping is enabled. User LBAs below are Physical LBAs.
NSRGroup
Re: Seagate 2tb EB1
Postby NSRGroup » 10.06.25, 11:18
AND after sector edit
ProcessRWError-Read-atLBA0000000000SenseCode=498000C8Out:
LED:0x000000BD FAddr:0x00007E3A
NSRGroup
Re: Seagate 2tb EB1
Postby NSRGroup » 11.06.25, 11:40
Hi again ,
i try to access to middle LBA HDD
I Have access to lba with 1-300 KB spped in middle or end of HDD LBA with all Head
and also dont have full access to terminal and terminal hang on
NSRGroup
Re: Seagate 2tb EB1
Postby NSRGroup » 11.06.25, 11:46
and Media Cash parser
MCT.RdResult............................ : Ok
Drive power supply...................... : ON
Data format version: 348 - AF
Scanning...
Checking for data duplication...
Duplicated sectors:
*none*
MCMT...
Header:
FormatKey................ : A79FDC3A
TimeStamp................ : 05290BC4F80C6151
MCSequenceNumber......... : 00000000
MSPSequenceNumber........ : 00000000
DiscDirtySegmentCount.... : 0000
SegHeadPtr............... : 00E8
SegTailPtr............... : 00E8
MSPBaseSegmentIndex...... : 4626
MCMTExtentCount.......... : 00000000
MCStateFlags1............ : 00020001
MCStateFlags2............ : 000A
Identifier............... : MTP
Footer:
Extent Info:
FirstExtentIndex......... : 6271A
LastExtentIndex.......... : 6271A
ExtentsCount............. : 0001
Parsing results:
Not commited extents..... : 0x0000 (0)
Extents in chain......... : 0x0000 (0)
Total not commited TRIM.. : 0x0000 (0)
TRIMs in extents chain... : 0x0000 (0)
Lost extents............. : 0
Search for possible chaiins...
Possible extent chain starters:
Start Node Stop Node Comment
*none*
Extents chain:
Node Previous Next Phys_Prev Phys_Next HostLBA(d) DiscHostLBA(d) Length(d) Flags
*none*
in MC, not commited:
*none*
in MC, commited / Rd cache:
*none*
NSRGroup
Re: Seagate 2tb EB1
Postby NSRGroup » 11.06.25, 16:14
I think should be regenerate translator but din't work terminal !!!?
is it posible regenerate tranlator without terminal ?
