Flash boot code Digital Signature Verification failure!
amnetdata
Postby amnetdata » 30.04.23, 23:19
Can someone provide a solution for Seagate 2TB Mobile ST2000LM007 PN:1R8174-570 FW:EB01 Site:TK FW:EB01 DOM:21NOV2022 PCB:100835923 REVB
Drive comes to ready with full ID but none of the sectors are accessible.
ROM is NOT readable through the terminal. I wrote unlock patched to the ROM externally and yet I can't send the UNLOCK signal through the PC-3000 terminal to the drive.
I used a matching DONOR pcb with transferred patient's ROM but I get this error message:
and the drive doesn't even turn on.
Here is my question, is there a way to change the Digital Signature of the patient's ROM to make it compatible with DONOR pcb controller's Digital Signature?
Thank You!
northwind
Re: Flash boot code Digital Signature Verification failure!
Postby northwind » 02.05.23, 10:09
That's an SBP3, still no (publicly available at least) solution.
You won't be able to unlock it.
amnetdata
Postby amnetdata » 02.05.23, 15:56
Thank You Northwind for your reply! Got it that's a bad news :(
kailash
Postby kailash » 16.06.26, 11:22
I am having this same problem, is there any solution available now?
italyassistance
Postby italyassistance » 23.06.26, 18:31
kailash wrote:Source of the post I am having this same problem, is there any solution available now?
yes now exist a solution unlock with terminal 3 for unblock terminal
