Can someone provide a solution for Seagate 2TB Mobile ST2000LM007 PN:1R8174-570 FW:EB01 Site:TK FW:EB01 DOM:21NOV2022 PCB:100835923 REVB
Drive comes to ready with full ID but none of the sectors are accessible.
ROM is NOT readable through the terminal. I wrote unlock patched to the ROM externally and yet I can't send the UNLOCK signal through the PC-3000 terminal to the drive.
I used a matching DONOR pcb with transferred patient's ROM but I get this error message:
Flash boot code Digital Signature Verification failure!
and the drive doesn't even turn on.
Here is my question, is there a way to change the Digital Signature of the patient's ROM to make it compatible with DONOR pcb controller's Digital Signature?
Thank You!
Re: Flash boot code Digital Signature Verification failure!
That's an SBP3, still no (publicly available at least) solution.
You won't be able to unlock it.
Thank You Northwind for your reply! Got it that's a bad news
I am having this same problem, is there any solution available now?
- italyassistance
- New user
kailash wrote:Source of the post I am having this same problem, is there any solution available now?
yes now exist a solution unlock with terminal 3 for unblock terminal
Users browsing this forum: Bing [Bot] and 10 guests
