88SS1074 BSW2 short pins
Issam
Postby Issam » 20.06.22, 11:55
I have the latest pc3000 version 7.1
Kindly tell me the short pins and how to build translator
thank you
Model: SUV400S37/960G
Manufacturer: Kingston
Name: Kingston Technology
Capacity: 960GB
Cover Label:
SUV400S37/960G
9904903-070.A04G
7792992- 1732
50026B7278013D3E
Controller Label:
88SS1074 BSW2
TPP1220A JW
1721 BJE
TW
Re: 88SS1074 BSW2 short pins
Postby Roman_TS » 20.06.22, 14:41
Every single manufacturer who is dealing with Marvell controller is writing its own firmware for each new model of SSD. As the
result, we should develop a new utility for every single Marvell-based case. Right now, we can work with the following models:
Sandisk SSD Plus
Sandisk Ultra II
WD Blue
All of them are based on Marvell 88SS1074. Other models, including the Kingston SUV400, I'm afraid, are not listed. Probably we will add them in the future, but I don't have any estimated time for now. Marvell's technology is extremely complex, developers spend around 18 months to add 88SS1074 support for these 3 models.
Issam
Postby Issam » 22.06.22, 11:19
Roman_TS wrote:Source of the post Hello,
Sandisk SSD Plus
Sandisk Ultra II
WD Blue
thank you dear Roman, you mean that my disk is not supported, right ?
Issam
Postby Issam » 22.06.22, 11:27
Can you tell me please how to connect to usb adapter i want to learn
Postby Roman_TS » 23.06.22, 16:04
No, it's not supported.
DRUG
Postby DRUG » 04.08.22, 12:30
I have solution for that model if you want to outsource.
italyassistance
Postby italyassistance » 07.05.26, 18:32
Hello i have micron C400 128 https://ibb.co/HL3Dx87K
https://ibb.co/gZSyMH1m
where is the point of shortcircuits?
Postby Roman_TS » 08.05.26, 09:14
italyassistance wrote:Source of the post Hello i have micron C400 128 https://ibb.co/HL3Dx87K
You don't need to short it. For old Marvell controllers techno mode goes via techno command, not via the SAFE MODE shorting and loader uploading.
If your C400 is in BSY state - leave it for 1-2 hours POWERED ON. It will reach Ready State soon. :wink:
italyassistance
Postby italyassistance » 09.05.26, 17:05
Hey roman thank u, u are right but i have an attention for u with build 7.8.22 marvel after state ready dont enter in tecno mode, even i installed older version 6.9 and I managed to upload the microcode and recover it. Any chance? Can you run some tests with the developers to confirm?
Postby Roman_TS » 11.05.26, 10:11
We will check the same drive on our side. But as far as I remember, we recovered a few C400 and also used the same C400 during ACE Lab trainings with no issue.
Return to “C400 Series”
