hello,
i have a ST3000DM001 with the following messages:
HDD family detecting...
Family ID: 58
Software can`t control COM port signal level for this USB/COM adapter
Selected family......................... : 58, Grenada
Model by ID............................. : ST3000DM001-1CH166
Loading default settings!
Then press OK!
Tech Key...
Requesting FW Pkg ver ........ GPG17D.CCD2.DC0CAL.CC27
Detecting SA Phys Sct Size...
Detecting UA Phys Sct Size...
Detecting Max Head number...
Phys. heads............................. : 6
Reading Saved Mode Pages...
Parsing Saved Mode Pages...
SMP Dbl: 0x3C001000 - 0x0001FFFF (0x0000000F)
Reading Registry File...
Parsing Registry File...
Media Cache
MC : enabled
MC Size : 0x43F188
MCMT Ver : MCMTV05
ID Len
0 36 Reserved Defect Table (SA defect table)
3 7782 Primary Defect File (P-List)
8 4800
B 1000
C 122880 Serial Port Test Results File (Self Scan Log)
D 160
F 223 DIC Dummy File
16 2
17 40
19 24 Log File
1A 33 Log File
1B 1 Log File
1C 9
2B 10118 R/W Operating Parameters (translator, etc)
33 4576
39 8192
3A 4
3D 3072 Disc firmware container 1
3E 3072 Disc firmware container 2
3F 4576 SED parameters
40 7 SED parameters
41 2180 SED parameters
42 4096 ST Ovl
43 10241 Defect list report file
44 1939440 BIG file
45 808580 BIG file
46 226172 BIG file
47 226172 BIG file
48 226172 BIG file
49 226172 BIG file
4A 226172 BIG file
4B 8192
4F 14336
51 18432
52 1024
53 8192
54 3984384
Collecting DT Infos...
ID MemOffs Len
0 40030200 40944 Read Adaptive Parameters File (RAP)
1 40030000 512 Controller Adaptive Parameters File (CAP)
4 1D400 7168 Servo Adaptive Parameter File (SAP)
40002000 13288
total 20456
A 25EA50 1024 Seek Profile
13 40139408 1440 Dependent Zone Table for User Area
14 401399A8 120 Dependent Zone Table for System Area
15 0 524288 Flash ROM
1D 40030220 424 VBAR Configuration File
1E 400305B8 4016 Zone Format Parameters File
26 40136F38 9424
27 40136D40 504
ID MemOffs Len
2 400303C8 496 Zone Table
40002000 13288
total 20456
6 1915C40 81964 Servo Flaw Table
16 40030200 32 Drive Configuration Table
17 400319A0 2016 Temperature Control Configuration
1F 4032C8E8 4500 RW working user preamp table
20 4032DA80 150 RW working system preamp table
26 40136F38 9424
27 40136D40 504
Collecting DT Infos completed
Reading autotuning buffer............... Ok
Buff Root FAT searching in RAM......... Ok
Searching volume 0 file table in RAM.... Ok
Searching volume 1/2 file table in RAM... Ok
Searching volume 3 file table in RAM.... Ok
Searching volume 4/5 file table in RAM... Ok
Request for volume 9/A file allocation table in RAM Ok
Searching SMP RAM FID in RAM............ Ok
Searching Non Resident G-List FID in RAM Ok
Searching CFW OVL FID in RAM............ Ok
Search for DBA Base in RAM.............. Ok
Search for RW Sys File DBA in RAM....... Ok
Search for MCMT RAM FD in RAM........... Error
i had the MCMT error before and fixed it with terminal commands but i have no terminal access now
any solutions how to reach access to terminal or how to solve the error else ?
thank you
ST3000DM001 MCMT error
Re: ST3000DM001 no terminal access
d1d wrote:Source of the post Software can`t control COM port signal level for this USB/COM adapter
This means you have PC USB Terminal 2 and software cannot change voltage which may be required or recommended for this model.
You can purchase PC USB Terminal 3 to solve the problem.
But as far as I remember ST3000DM001 can work with Terminal 2 without issues.
Double check the connection just to be sure.
i have USB Terminal 3 and also checked the connection.
it works fine with other drives
i have termial access now but i have two errors.
and
i tried to regenerate MCMT but i did not work.
anyone know how to solve the problem ?
and
Re: ST3000DM001 MCMT error
d1d wrote:Source of the post i have termial access
please send terminal output after power up
Maxim_TS wrote:Source of the post please send terminal output after power up
i managed to save the data via DE so i unfortunately i dont have the drive here anymore
d1d wrote:Source of the postMaxim_TS wrote:Source of the post please send terminal output after power up
So you didn't resolve MCMT issues but just imaged the drive?
