Would greatly appreciate short points on PCB 100706008 as per attached. Drive patched, but cannot gain access to terminal to unlock via patch
Short points for ST4000DX000
Re: Short points for ST4000DX000
Even though I'm not sure I understand what you mean by "cannot gain access to terminal to unlock via patch", here:
modified patch rom was applied now when drive cycles can not get gain access to terminal. those red point where the ones i was using, but guess my timing is off. Any help with timing
here is output at startup and just repeat v00000008q
Boot 0x80M
Spin Up
RECOV Servo Op=0100 Resp=0005
Trans.
(P) SATA Reset
Last Saved GlobalHeader EraseInProgress:02 DiscDataValid:00
ISP: 43A17830 00001FE8 E441 0000
TW: 1EF7D947 00000FF8 594C 0000[000000000052A857]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV00000008qV
Boot 0x80M
Spin Up
Trans.
(P) SATA Reset
