vbga-100 chipset
Typical Flash recovery cases
SLAB_TEAM0
vbga-100 chipset
Postby SLAB_TEAM0 » 15.09.20, 18:05
Hi.
Need to read a set of vbga-100 chips. Is there a pinout scheme to use soldering by Circuit Board adapter, or we need to buy its adapter?
Thank you in advance for aswers
Re: vbga-100 chipset
Postby Roman_TS » 16.09.20, 12:26
You can try to solder it via Circuit Board, but the whole process will be much more complex than a common reading via adapter.
But if you have a lot of free time - it's up to you :)
P.S. All ONFI pinouts you can find in ONFI.ORG
Postby Amarbir[CDR-Labs] » 18.09.20, 06:21
Hi ,
Its Very Rare To Have VBGA-100 Flash Device ,Can You Post a Picture of It Here ,It Will Be Interesting ....
Postby Roman_TS » 18.09.20, 10:35
Amarbir[CDR-Labs] wrote:Source of the post Hi ,
VBGA-100 are usually used in Compact Flash cards. Sometimes you can meet them in SD cards. But they are very rare in USB sticks.
