Hi.
Need to read a set of vbga-100 chips. Is there a pinout scheme to use soldering by Circuit Board adapter, or we need to buy its adapter?
Thank you in advance for aswers
vbga-100 chipset
Re: vbga-100 chipset
You can try to solder it via Circuit Board, but the whole process will be much more complex than a common reading via adapter.
But if you have a lot of free time - it's up to you
P.S. All ONFI pinouts you can find in ONFI.ORG
- Amarbir[CDR-Labs]
Hi ,
Its Very Rare To Have VBGA-100 Flash Device ,Can You Post a Picture of It Here ,It Will Be Interesting ....
Amarbir[CDR-Labs] wrote:Source of the post Hi ,
VBGA-100 are usually used in Compact Flash cards. Sometimes you can meet them in SD cards. But they are very rare in USB sticks.
