List of compatible SATA PCB for 2,5" USB drives
murphman
Re: List of compatible SATA PCB for 2,5" USB drives
Postby murphman » 15.04.19, 21:10
I also have a WD20SMZM-59H3FS1 with 2060-810003 PCB. Did anyone figure out what SATA board is compatible with this model?
I'm assuming these are WD20SPZX converted to USB drives (WD20SMZM) but I could be wrong. Also these drives do not have a DCM; anyone know a good way to match the heads or at least the PCB for SATA on this model???
savedata
Postby savedata » 30.05.19, 12:08
USB 800069 SATA 800066
Postby AJ2008 » 31.05.19, 10:00
murphman wrote:Source of the post I also have a WD20SMZM-59H3FS1 with 2060-810003 PCB. Did anyone figure out what SATA board is compatible with this model?
This looks like Charger and is locked much the same as Palmer so you may need to look into an unlocked PCB for it
Freakazoid
Postby Freakazoid » 06.02.20, 05:49
Hello i have a wster digitat with pcb 771964 and need a compatible sata pcb what kind do I need then?
Maxim_TS
Postby Maxim_TS » 06.02.20, 09:58
Freakazoid, there is no SATA PCB for these drives, at least we don't know about that. Try to sodler SATA adapter
Expand view
Collapse view
k4z1
Postby k4z1 » 06.02.20, 10:04
lcoughey wrote:Source of the post Any suggestions for this drive?
Model: wd20smzm-59h3fs1
USB C PCB: 2060-810003-001
2060-800065
Maxim_TS wrote:Source of the post lcoughey, we didn't see such drives here in support.. Have you tried to solder SATA adapter to see if the drive allows to read SA?
This is a charger drive, SA access is locked.
Only with unlock PCB we can do something with that drive.
Mehboob
Postby Mehboob » 13.02.20, 12:38
can we use 800062-002 for wd20smzw-11yfcs0 usb?
is there two versions of rom?do we need 2 different pcb for these roms or we can only transfer the rom and it works.
Mehboob
sorryn 800065
Mehboob
Postby Mehboob » 01.03.20, 05:36
anybody has resources for this drive means "loader"
crashpcberlin
Postby crashpcberlin » 18.05.20, 20:07
I have just solved the slow responding problem via ROM-soldering on a WD40NMZM (Spyglass) with a USB-C PCB: 2060-810012-000 using a 2060-800022-002 SATA-PCB.
Worked fine, so i think you can add them to the list.
Postby DataMedics » 20.05.20, 22:27
Freakazoid wrote:Source of the post Hello i have a wster digitat with pcb 771964 and need a compatible sata pcb what kind do I need then?
Have you tried using a 2060-771927 or a 2060-771983 board? Looks very similar to those two although some components are moved around.
Maxim_TS
Postby Maxim_TS » 21.05.20, 15:43
crashpcberlin, added, thank you!
Reza Amiri
Postby Reza Amiri » 02.08.20, 15:11
Thanks Dear maxim
pcimage
Postby pcimage » 09.06.21, 18:32
WD Big bear...
2060-771964 USB >> 2060-771983 SATA
Maxim_TS
Postby Maxim_TS » 07.07.21, 16:59
pcimage wrote:Source of the post WD Big bear
added, thank you!
Return to “WD USB”
