Intel M2 SSD model: SSDSCKKF512H6
jimmy
Postby jimmy » 25.05.18, 08:18
Dear TS,
Does the SSD supported by PC3K?
Model: SSDSCKKF512H6
Search on internet, it should be belong to SSD 540S, but the controller is not SMI SM2256EN but somthing like " SMI N05K80.00 / S LLUS / TW 1637 4D
picture is attached.
Re: Intel M2 SSD model: SSDSCKKF512H6
Postby Roman_TS » 25.05.18, 09:02
Controller is SM2258. Not sure when exactly this model will appear in support list because Intel totaly modifed default firmware of SM2258 Controller. We can't use default SM commands for TechMode activation on this drive.
jimmy
Postby jimmy » 25.05.18, 11:47
Thanks a lot.
Jimmy
Postby Amarbir[CDR-Labs] » 22.05.19, 09:34
Roman,
Today i got this one ,Is this supported Now As SM2258 is Now Supported In PC 3000 SSD Tool
Postby Roman_TS » 22.05.19, 13:22
Amarbir[CDR-Labs] wrote:Source of the post Roman,
List of supported drives you can find here:
https://blog.acelab.eu.com/pc-3000- ... dated.html
encikanis
Postby encikanis » 27.06.19, 04:01
any luck with this model?
Postby Roman_TS » 27.06.19, 07:23
encikanis wrote:Source of the post any luck with this model?
If this model will appear in support list, you will find it in our article - List of supported SSDs.
Return to “Other SSD Intel”
