Hey guys
I'm struggling with a ST3000DM001 here..
I have swapped heads on it (same preamp), but I get this log.
I checked heads under microscope and they don't show any dust.
I swapped heads back again to donor and it seems that head 3 (at least that one) failed. If I do a SAP change to use 0,1,2, the drive ID's fine (the donor).
I tried also to import head adaptives, but same thing.
What do you guys think? Media damage? Or some kind of FW problem?
The only thing I haven't tested was the PCB, since I don't have an exact match and the PCB from donor is different.
ST3000DM001
ST3000DM001
- Attachments
- Log Grenada.txt
- (56.32 KiB) Downloaded 514 times
Re: ST3000DM001
Translator was not read, you'd have to fix it later
Drive is busy walking through MC and marking bad sectors, wait until it stops doing so (could take hours)
Also you saying that H3 is bad, that could mean the drive is developing MD, make sure you address this issue before you let the drive parse MC
Re: ST3000DM001
Hi @Doomer
So, I should let it run and see what happens?
Re: ST3000DM001
you need to make sure there is no MD on H3, if there is - cut the head
after that, yes, let it run
very possible it would show No Host FIS error, because translator was not read, fix the translator(assuming heads can write) and drive should come ready if there are no more surprises
Re: ST3000DM001
Thanks Doomer
I will try tomorrow, since I don't want to leave it during the night without babysitting eheheheh
Re: ST3000DM001
Hi again @doomer
So, I left it work until it stops. After getting to the end it stays BSY and nothing else on terminal.
Here's the log.
PS: I tried 2 times to power on/off.
Here's the log.
- Attachments
- Grenada Log.txt
- (551.03 KiB) Downloaded 523 times
Re: ST3000DM001
Log really looks incomplete to me
Are you sure drive does not do anything after this, maybe wait some more?
Re: ST3000DM001
It continues ON, but BSY.
Re: ST3000DM001
So I left it on during the night.
Now it keeps spitting this out:
RECOV Servo Op=006B Resp=0005
RECOV Servo Op=056B Resp=0005[000000002BC10F5D]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F5E]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F5F]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F60]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F61]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F62]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F63]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F64]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F65]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F66]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F67]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F68]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F69]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F6A]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F6B]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F6C]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F6D]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F6E]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F6F]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F70]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F71]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F72]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F73]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F74]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F75]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F76]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F77]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F78]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F79]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F7A]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F7B]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F7C]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F7D]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F7E]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F7F]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F80]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F81]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F82]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F83]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F84]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F85]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F86]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F87]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F88]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F89]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F8A]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F8B]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F8C]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F8D]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F8E]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F8F]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F90]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F91]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F92]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F93]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F94]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F95]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
Users browsing this forum: Bing [Bot] and 12 guests
