ST3000DM001
pclab
ST3000DM001
Postby pclab » 09.04.19, 17:37
Hey guys
I'm struggling with a ST3000DM001 here..
I have swapped heads on it (same preamp), but I get this log.
I checked heads under microscope and they don't show any dust.
I swapped heads back again to donor and it seems that head 3 (at least that one) failed. If I do a SAP change to use 0,1,2, the drive ID's fine (the donor).
I tried also to import head adaptives, but same thing.
What do you guys think? Media damage? Or some kind of FW problem?
The only thing I haven't tested was the PCB, since I don't have an exact match and the PCB from donor is different.
Log Grenada.txt
(56.32 KiB) Downloaded 515 times
Doomer
Re: ST3000DM001
Postby Doomer » 09.04.19, 18:49
Translator was not read, you'd have to fix it later
Drive is busy walking through MC and marking bad sectors, wait until it stops doing so (could take hours)
Also you saying that H3 is bad, that could mean the drive is developing MD, make sure you address this issue before you let the drive parse MC
pclab
Re: ST3000DM001
Postby pclab » 09.04.19, 18:52
Hi @Doomer
So, I should let it run and see what happens?
Doomer
Re: ST3000DM001
Postby Doomer » 09.04.19, 18:55
pclab wrote:Source of the post Hi Doomer
you need to make sure there is no MD on H3, if there is - cut the head
after that, yes, let it run
very possible it would show No Host FIS error, because translator was not read, fix the translator(assuming heads can write) and drive should come ready if there are no more surprises
pclab
Re: ST3000DM001
Postby pclab » 09.04.19, 18:57
Thanks Doomer
I will try tomorrow, since I don't want to leave it during the night without babysitting eheheheh
pclab
Re: ST3000DM001
Postby pclab » 10.04.19, 17:46
Hi again @doomer
So, I left it work until it stops. After getting to the end it stays BSY and nothing else on terminal.
Here's the log.
PS: I tried 2 times to power on/off.
Grenada Log.txt
(551.03 KiB) Downloaded 525 times
Doomer
Re: ST3000DM001
Postby Doomer » 10.04.19, 18:02
Log really looks incomplete to me
Are you sure drive does not do anything after this, maybe wait some more?
pclab
Re: ST3000DM001
Postby pclab » 10.04.19, 18:32
It continues ON, but BSY.
pclab
Re: ST3000DM001
Postby pclab » 11.04.19, 08:28
So I left it on during the night.
Now it keeps spitting this out:
RECOV Servo Op=006B Resp=0005
RECOV Servo Op=056B Resp=0005[000000002BC10F5D]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F5E]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F5F]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F60]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F61]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F62]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F63]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F64]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F65]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F66]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F67]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F68]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F69]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F6A]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F6B]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F6C]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F6D]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F6E]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F6F]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F70]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F71]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F72]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F73]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F74]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F75]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F76]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F77]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F78]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F79]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F7A]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F7B]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F7C]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F7D]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F7E]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F7F]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F80]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F81]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F82]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F83]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F84]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F85]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F86]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F87]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F88]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F89]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F8A]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F8B]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F8C]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F8D]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F8E]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F8F]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F90]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F91]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F92]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F93]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F94]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
RECOV Servo Op=056B Resp=0005[000000002BC10F95]v00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008qv00000008q
