Hi everyone,
I've got a Rosewood family drive P/N: 1R8174-568 F/W:SBK2 ST2000LM007 that needs new heads. Ordered a donor but the heads are a different revision given the sticker. Is there a process to transfer the adaptives from the donor to the patient rom?
Thanks!
Rosewood adaptive transfer and head matching
- DNC_Scotty
Re: Rosewood adaptive transfer and head matching
In my experience you don't need adaptives transfer on Rosewoods
- DNC_Scotty
That ended up being true. The donor I was using ended up being defective. The second donor worked like a charm!
- Amarbir[CDR-Labs]
i always use brand new drives for donors in rosewoods
Doomer wrote:Source of the post In my experience you don't need adaptives transfer on Rosewoods
Indeed!!!
I use brand new donor drive HSA too, the problem is after a while it start to skip sector (yellow) then if I change with another HSA I'm able to go ahead with image.
Result are that more drive are require to complete an image.
Someone got some suggestion
Are the failing heads contaminated after the short use? Perhaps just clean them and re-try.
- DNC_Scotty
How do the heads operate once place back into the donor hd?
