The patient hsa bad head 2. used Donor, drive doesn't ID with DONOR. but PATIENT HEAD can ID in DONOR.
Patient Head works in both - DONOR N PATIENT
But DONOR head works in only DONOR, Doesn't work at PATIENT
Have you ever faced such issue?
Strange Behaviour WD10EARS
Re: Strange Behaviour WD10EARS
since patient can never show ID, but patient heads are working in donor, then compatibility should be good but you must have different issues.
With donor heads in patient, and regions blocked in ROM, does spindle stay powered? Can you read SA? did you try donor PCB on patient HDA? Are you sure ROM/PCB is original on patient?
I guess you have some other issues in this case.
shahi wrote:Source of the post but PATIENT HEAD can ID in DONOR.
what head map in both donor and patient?
AJ2008 wrote:Source of the post since patient can never show ID, but patient heads are working in donor, then compatibility should be good but you must have different issues.
The Paitent HDD Ids normally, it has 1 bad head out of 4 heads. Imaged 3 good heads, then tried DONOR head and with DONOR Head the Drive doesn't ID, but the Patient Head works in DONOR. So it's not compatibility issue.
Yes, tried donor PCB on patient. Yes they are original.
Maxim_TS wrote:Source of the postshahi wrote:Source of the post but PATIENT HEAD can ID in DONOR.
Both 4 heads
did you import head adaptive parameters from donor ROM to patient ROM?
shahi, try the DONOR heads back in DONOR to be sure that DONOR heads are not damaged somehow.
AJ2008 wrote:did you import head adaptive parameters from donor ROM to patient ROM?
Will try this today
Maxim_TS wrote:shahi, try the DONOR heads back in DONOR to be sure that DONOR heads are not damaged somehow.
I've yes, checked, donor heads are still fine and working once taken back
shahi wrote:Source of the post but the Patient Head works in DONOR. So it's not compatibility issue.
If you played with head adaptives and it didn't help, then the only sensible reason is that platter under unreadable head is damaged somehow.
Played with head adaptives as well, it didn't help. Ordered another donor and waiting for the DONOR
Another Donor helped to solve the issue
shahi, great to hear good news, thank you for sharing the result!
