I have a NAND chip from a SKhynix,
H2JTFG8YD1BMS
BC A0 441A
Photo attached.
Which adapter to use?
TLGA-52?
Thanks.
Phil
Which adapter to use, TLGA-52?
Re: Which adapter to use, TLGA-52?
Hello!
This is TLGA-60 - it has 8 addition pins in central raw. You can try to read it with TLGA-52, but there might be issues.
Hello Oldman,
I have the same problem,
I need to read the Nand chip H2JTFG8YD3MBR, this is too TLGA-60.
Could you to read the chip with apdapter TLGA-52?
Thank and regards.
Thank and regards.
For reading BGA-60 with TLGA-52 adapter, you have to chose reading scheme number 1785, and ignore all others during chip reading. It will help.
- Amarbir[CDR-Labs]
Roman_TS wrote:Source of the post For reading BGA-60 with TLGA-52 adapter, you have to chose reading scheme number 1785, and ignore all others during chip reading. It will help.
Well,
if i was at his place i will hardwire the chip to a monolith board
I have never had success reading in TLGA-52 reader, but I only see this a small number of times so is not a problem to wire manually for reading
Sorry for the delay as it is such old post, seem that I was not able to read and recover it successfully.
I can not read it,
what is the pinout of the chip, to try to read the chip
I can not read it,
Users browsing this forum: Bing [Bot] and 9 guests
