hi
anyone can show how to make USB to SATA connection of WD 4 tb model:WD40NMZW-11GX6S1 AND PCB no is : 2060-800041-003 REV P1 .The pics of the PCB given in the same post. i am not able to find out the 4 PF which i need to remove . I can see the E71,E72,E73 and E75. But in the inside portion there is no reference marking of PF.
Any one have idea plz lead me.
Betty
- Attachments
- IMG_20170301_8000xx_port1.jpg (14.11 KiB) Viewed 23823 times
- IMG_20170301_8000xx_port1 (1).jpg (14.11 KiB) Viewed 23823 times
Re: USB to SATA connection of WD 4 tb model:WD40NMZW-11GX6S1
betty wrote:Source of the post i am not able to find out the 4 PF which i need to remove
https://imgur.com/LdT6YM8
thanks Maxim...
betty
betty
betty, you are welcome!
don't forget to make the wires as short as possible.
You will need to decrypt data if SED is not active.
Active SED - data reads unencrypted
Disabled SED - data reads encrypted
I do not think you can decrypt this in PC3000. Also, it will not read with security active. I also believe removing this password will affect encryption (you can test it at mod 124 or 127 - I dont remember exactly) but back up all SA first, clear password module, then put SED back and check now if you get sector access while SED is active and password is removed. If any problems, then restore original copies of modified modules.
Other option is make image with SED off and data encrypted, then restore image to other spyglass with SATA conversion and SED disabled, and write relevant modules relating to encryption (such as password module and encryption key if known) then restart donor as USB and check if client data can be saved.
But depending on the reason you convert to SATA, maybe you can fix problem and return to original condition (i.e. USB interface, SED on, Drive is locked on etc) then decrypt and extract while connected over USB
hello UDMAbod,
Can you show me the picture of connection points for the usb to sata conversion. or explain ?.. because i also tried for the same.. but there have no DRD &DSC register.
betty
betty
connection scheme is showed via link in 2nd post of this topic.
How to solder SATA adapter to USB board you can read in this article:
http://blog.acelab.eu.com/pc-3000-h ... drive.html
- huangmiaofang
This hard drive can read and write firmware after unlocking the SED,
but it cannot create head bitmap
huangmiaofang, it would be better if you submit a new topic about your issue, because we don't know the story of your drive. Right now you just wrote that some your drive can't create bitmap, it's not enough for correct diagnostics.
- huangmiaofang
