Rosewood_A5 / Error: Translator regeneration error! Err: 0x9
IMP
Re: Rosewood_A5 / Error: Translator regeneration error! Err: 0x9
Postby IMP » 05.12.17, 06:47
We get so many Rosewood family drives with Translator issue
Its high time ACE should come out with solution on this.
Just giving unlocking solution is half solution
We feel like we are handicapped :cry: :cry: :cry:
Postby AJ2008 » 19.12.17, 14:36
there is solution for this. When translator is rebuilt, it restores many values in many modules, and native translator module can be restored back after full regeneration has completed - this will retain Media Cache and any Post Processing defects while allowing repair of the translator / MC issue.
Complications occur when there is some inability to read translator module, where other DR company with limited experience has it first or where there is some mechanical problem like head damage.
Postby Amarbir[CDR-Labs] » 19.12.17, 15:25
Dmitriy_TS wrote:Source of the post Dear Amarbir,
Amarbir[CDR-Labs] wrote:Source of the post Well ,
Understood This But Whats The Difference ?
For the drives where system files are read via ATA direct mode, you can read system file by typing volume, file id and copy of the file in the top sys files tab.
For the drives where system files are read via ATA indirect mode, you have to upload module and system files table in the utility and then check the box of the system file in the sys file tab to read file. You have to follow this procedure because of ATA indirect mode requires mode parameters (Volume, FileID, Copy and other). When you check the box you lay down system file parameters automatically.
Dimitry ,
How Do You upload module and system table in the utility .I asked the same question in the blog post also but i did not get a satisfied answer
Postby Amarbir[CDR-Labs] » 19.12.17, 15:26
AJ2008 wrote:Source of the post there is solution for this. When translator is rebuilt, it restores many values in many modules, and native translator module can be restored back after full regeneration has completed - this will retain Media Cache and any Post Processing defects while allowing repair of the translator / MC issue.
AJ Sir ,
Can You Expalin Me the same in little details
Postby AJ2008 » 19.12.17, 15:40
Try this:
Read ROM
Patch ROM
Repower HDD
Send Handshake
Read translator system file via terminal or ATA direct mode
Regen translator
Repower
Send handshake again
Write translator file back to relevant module (not system file)
Restore original unpatched ROM if required then restart HDD and read data
Postby Amarbir[CDR-Labs] » 19.12.17, 16:02
AJ2008 wrote:Source of the post Try this:
Read ROM
Patch ROM
Repower HDD
Send Handshake
Regen translator
Repower
Aj ,
Reading Translator system file and writing to module not sys file is this what you said
Postby AJ2008 » 19.12.17, 16:04
yes
Filipp_TS
Postby Filipp_TS » 18.01.18, 14:03
2 months since Blog article release.
http://blog.acelab.eu.com/pc-3000-f ... ackup.html
