ST2000dm001 init fail
emir_has
Postby emir_has » 13.09.17, 21:21
I have ST2000DM001 and when i power on in terminal i got this message:
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
(P) SATA Reset
And it freeze on this.
When i power it up and press CTRL+Z i got terminal mode ready and then i hit CTRL+X and get this message:
F3 T>
ATA 15 Cmds
Ts(ms) dT(ms) Op Cnt LBA
0 99999999 00 0000 000000000000
0 0 00 0000 000000000000
RW 32 Cmds
Ts(ms) dT(ms) xT(ms) Type Option Mode St EC Info
4559 99999999 6 02 011201 000000 1 00000080 XFR RD SYS LBA B 00000003ADD5 L 000000000051 BO 000000 BES 03BF800.05FFFFF.03BF800
4591 32 8 02 011201 000000 1 00000080 XFR RD SYS LBA B 00000003AE26 L 000000000001 BO 000000 BES 022D280.022D2BF.022D280
4599 8 77 02 028201 000000 1 00000080 XFR WR SYS LBA B 00000003AE26 L 000000001195 BO 000200 BES 022D280.022D2BF.022D280
4676 77 6 02 028201 000000 1 00000080 XFR WR SYS LBA B 00000003ADD5 L 000000000051 BO 000000 BES 03BF800.03C0C3F.03BF800
4682 6 8 02 028201 000000 1 00000080 XFR WR SYS LBA B 00000009D917 L 000000000051 BO 000000 BES 03BF800.03C0C3F.03BF800
4691 9 9 02 028201 000000 1 00000080 XFR WR SYS LBA B 0000000352F6 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
4700 9 9 02 028201 000000 1 00000080 XFR WR SYS LBA B 000000097E38 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
4709 9 0 27 028201 000000 1 00000080 SND_SRV 0C01 0000 0000 0000 0000 0000 0000 0000
0000 0000 0000 0000 0000 0000 0000 0000
0001 D7EA 00D0
6738 0001 FFFF FFFC 0004 04A0 1A00 DA0A
0003 0FA3 0F91 0F80 0F77 0F87 109D 1067
7AAA 5DFE A6F8 4974 1020 628A C002 1FE3
42CF 31B5 52FE D6E8 6018 5A1A 88B4 9EC0
4709 0 7 02 011201 000000 1 00000080 XFR RD SYS LBA B 00000003FDBB L 000000000001 BO 000000 BES 0068487.00684C6.0068487
4716 7 5 02 011201 000000 1 00000080 XFR RD SYS LBA B 0000000408BE L 000000000003 BO 000000 BES 00684C7.0068586.00684C7
4721 5 8 02 011201 000000 1 00000080 XFR RD SYS LBA B 00000003C298 L 000000000308 BO 000000 BES 03B3600.03BF7FF.03B3600
4736 15 113 02 011201 000000 1 00000080 XFR RD SYS LBA B 00000003C5BB L 000000003800 BO 000000 BES 0068F67.0148F66.0068F67
5035 299 5 02 011201 000000 1 00000080 XFR RD SYS LBA B 00000003ADF1 L 000000000002 BO 000000 BES 022D280.022D67F.022D280
5040 5 9 02 028201 000000 1 00000080 XFR WR SYS LBA B 00000003ADF1 L 000000000002 BO 000000 BES 022D280.022D2FF.022D280
5049 9 8 02 028201 000000 1 00000080 XFR WR SYS LBA B 00000009D933 L 000000000002 BO 000000 BES 022D280.022D2FF.022D280
5057 8 8 02 011201 000000 1 00000080 XFR RD SYS LBA B 00000003ADF1 L 000000000002 BO 000000 BES 022D280.022D67F.022D280
5083 26 7 02 028201 000000 1 00000080 XFR WR SYS LBA B 00000003ADF3 L 000000000001 BO 000000 BES 00689E7.0068A26.00689E7
5090 7 8 02 011201 000000 1 00000080 XFR RD SYS LBA B 00000003ADD7 L 000000000004 BO 000000 BES 022D280.022D37F.022D280
5098 8 9 02 011201 000000 1 00000080 XFR RD SYS LBA B 00000003ADD7 L 000000000004 BO 000000 BES 022D680.022D77F.022D680
5107 9 8 02 028201 000000 1 00000080 XFR WR SYS LBA B 00000003ADD7 L 000000000004 BO 000000 BES 022D680.022D77F.022D680
5115 8 6 02 011201 000000 1 00000080 XFR RD SYS LBA B 0000000C5684 L 000000000001 BO 000000 BES 0241A80.0241ABF.0241A80
5128 13 61 02 011101 000000 1 00000080 XFR RD USR LBA B 000000001294 L 000000000762 BO 24000E74 VL E89C.3B10
5189 61 32 02 028201 000000 1 00000080 XFR WR SYS LBA B 00000003C298 L 000000000308 BO 000000 BES 03B3600.03BF7FF.03B3600
5221 32 25 02 028201 000000 1 00000080 XFR WR SYS LBA B 00000009EDDA L 000000000308 BO 000000 BES 03B3600.03BF7FF.03B3600
5246 25 4 02 028201 000000 1 00000080 XFR WR SYS LBA B 0000000352F6 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
5251 5 8 02 028201 000000 1 00000080 XFR WR SYS LBA B 000000097E38 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
5261 10 35 02 011101 000000 1 00000080 XFR RD USR LBA B 000000000000 L 00000000010C BO 24000E74 VL 2C9C.0860
5338 77 17 02 028101 000000 1 00000080 XFR WR USR LBA B 000000000000 L 00000000010C BO 24000E74 VL 389C.0860
5355 17 19 02 011201 000000 1 00000080 XFR RD SYS LBA B 0000000373D5 L 000000000001 BO 000000 BES 00650DD.006511C.00650DD
5374 19 9 02 011201 000000 1 00000080 XFR RD SYS LBA B 0000000373D5 L 000000000001 BO 000000 BES 00650DD.006511C.00650DD
5383 9 9 02 028201 000000 1 00000080 XFR WR SYS LBA B 0000000352F6 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
5392 9 8 02 028201 000000 1 00000080 XFR WR SYS LBA B 000000097E38 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
Also once i get this message LED:000000BD FAddr:00005657 but only once!
There is no clicking, drive start normaly spindle up normaly no wierd sounds. Falgs DRD DSC are on!
Please help me?
P.S. S.M.A.R.T. reset didnt helped me in terminal level 1 with N1 command.
emir_has
Re: ST2000dm001 init fail
Postby emir_has » 14.09.17, 09:41
I have made to reset media cashe and got drive initialized (followed these instructions: http://www.hddoracle.com/viewtopic.php?f=83&t=1579 ). It is slow initialization but it read HDD ID but i got new message in log:
SMP Dbl: 0x3C001000 - 0x0001FFFF (0x0000000F)
I cannot read SAP, RAP
How can i solve this problem?
Thank you
Masterclass
Postby Masterclass » 14.09.17, 10:08
emir_has wrote:Source of the postfollowed these instructions: http://www.hddoracle.com/viewtopic.php?f=83&t=1579 )
Keep following stupid instructions to finally brick your drive with customer's data...
emir_has
Postby emir_has » 14.09.17, 11:13
Sorry you mean that i brick user data now??
Masterclass
Postby Masterclass » 15.09.17, 04:54
Do you have the least understanding of commands you type in terminal?
If yes, please explain each command and why do you think it is required to use it
emir_has
Postby emir_has » 15.09.17, 07:49
I know that my questions are silly, but try to understand I'm beginner in Seagate drivers so I am little bit confused!.
Please, can you tell me how can I fix this situation and is there any chance to get to user data?
This proceudure i used, mentioned above i understand that I have read data from cache memory then i wrote zeroes except last portion and then reinitialize cache?
Thanks in advance and sorry again.
Nick_TS
Postby Nick_TS » 20.09.17, 18:46
Hello Emir,
Please send terminal command
F3 T>/1N1
And give us output.
emir_has
Postby emir_has » 22.09.17, 20:26
Clear SMART is completed.
F3 1>
emir_has
Postby emir_has » 23.09.17, 20:32
Now when i want to backup driver resources i got error savin SAP and RAP pages. How can i solve problems with SAP and RAP?
