ST1000LM035 Rosewood A5 not reading SA
Joeb16
Postby Joeb16 » 31.07.17, 17:30
I am trying to read SA from this drive but the PC3000 keeps reporting an error. This drive seems to be working fine.
“Error initializing microprogram tables” Detecting SA Phys Sct Size...
Can not detect SA phys secotr size by ATA!
Terminal : error detecting HDD terminal baud rate
Test : HDD resources backup
Folder: C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Rosewood_A5\ST1000LM035-1RK172-SBM3-WDE0FDYJ\Data\SABackup\
Reading ROM to profile folder
Folder: C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Rosewood_A5\ST1000LM035-1RK172-SBM3-WDE0FDYJ\Data\SABackup\ROM\
Error : DT ID 15 is not found!
Backup of service information completed
Masterclass
Re: ST1000LM035 Rosewood A5 not reading SA
Postby Masterclass » 01.08.17, 09:31
patch fw - write patched ROM - repower - provide handshake reply. All these steps were followed?
Joeb16
Postby Joeb16 » 04.08.17, 16:48
I did follow the steps but should have tried it a few more times. I was not able to get the terminal to read the board ROM. It took me about 5 times before it was able to read to read the ROM. I am not sure if it was my port connection or the drive or that the board’s read channel needs to be jumped first.
Nick_TS
Postby Nick_TS » 04.08.17, 21:33
Joeb16 wrote:Source of the post I did follow the steps but should have tried it a few more times. I was not able to get the terminal to read the board ROM. It took me about 5 times before it was able to read to read the ROM. I am not sure if it was my port connection or the drive or that the board’s read channel needs to be jumped first.
Could you post here the terminal output after handshake reply?
