Seagate F3
Added correction to avoid hangup of hybrid drives Kahuna family in case of NAND damage (for CFW ROM);
I try. But it not work.
HELP.! correction to avoid hangup of hybrid drives Kahuna family in case of NAND damage . I't not Work!
- cuumaytinh
Re: HELP.! correction to avoid hangup of hybrid drives Kahuna family in case of NAND damage . I't not Work!
Is any one from tech support able to explain the circumstances to which this patch should be applied? Is this to be used as an alternative to swapping a failed SSHD PCB with donor in instances of NAND failure?
Thanks,
A
Thanks,
A
I'm also interested in this topic.
- Masterclass
cuumaytinh wrote:Source of the post But it not work
Which FW version do you have?
Hi ACE Staff.
Can you please write an article on how to use the “Kahuna CFW patch 1” to fix Seagate SSHD?
Thank you
-BR-
Thank you
-BR-
