HELP.! correction to avoid hangup of hybrid drives Kahuna family in case of NAND damage . I't not Work!
cuumaytinh
Postby cuumaytinh » 08.07.17, 08:17
Seagate F3
Added correction to avoid hangup of hybrid drives Kahuna family in case of NAND damage (for CFW ROM);
I try. But it not work.
seagate sshd.jpg (486.4 KiB) Viewed 19997 times
avalanche
Re: HELP.! correction to avoid hangup of hybrid drives Kahuna family in case of NAND damage . I't not Work!
Postby avalanche » 10.07.17, 22:09
Is any one from tech support able to explain the circumstances to which this patch should be applied? Is this to be used as an alternative to swapping a failed SSHD PCB with donor in instances of NAND failure?
Thanks,
A
studiogsm
Postby studiogsm » 10.07.17, 22:20
I'm also interested in this topic.
Masterclass
Postby Masterclass » 11.07.17, 12:14
cuumaytinh wrote:Source of the post But it not work
Which FW version do you have?
-BR-
Postby -BR- » 25.07.17, 06:02
Hi ACE Staff.
Can you please write an article on how to use the “Kahuna CFW patch 1” to fix Seagate SSHD?
Thank you
-BR-
