Segate ST500dm002
emir_has
Segate ST500dm002
Postby emir_has » 14.12.16, 20:19
I have Segate ST500dm002-1bd142-021 fw. hp73
I have problem with init of the disk. I identifies as wrong disk with capacity 3,4GB. I think ROM is corrupted!
Please give me some advice how to initialize the dis correctly. I have same disk as donor, can I use his ROM???
emir_has
Re: Segate ST500dm002
Postby emir_has » 14.12.16, 20:20
In terminal i get this message: LED:000000EE FAddr:0010289C
emir_has
Postby emir_has » 15.12.16, 20:36
I have made to read ROM in Boot Code mode. All data are ok, ROM, HDD ID, CAP,SAP,RAP.
What I should do now to get correct hdd initialization when startin hdd in normal mode???
Please help
emir_has
Postby emir_has » 15.12.16, 21:13
Can i write saved ROM from BOOT code to donor PCB and put it on patient hdd?
Filipp_TS
Postby Filipp_TS » 16.12.16, 17:13
Yes, you can.
But try to get a terminal access by shorting procedure then check a critical sys files (like 28, 35, 1B etc) , all of them are OK?
