An easy way to transferring data to HFS+ drive
osity
Postby osity » 26.09.16, 19:14
In the past I have run into some issues with giving back data on Exfat for "Mac only" users.
Is there a way to transfer data from DE directly to HFS+?
For "mac only" users I find myself having to transfer from DE to Exfat, then from Exfat to HFS+.
Having to transfer twice is time consuming. Is this the most efficient way if I want the client to have HFS+ only?
Re: An easy way to transferring data to HFS+ drive
Postby DataMedics » 26.09.16, 21:40
osity
Postby osity » 26.09.16, 22:54
Thanks, I'll check it out. At 49.99 that seems like a bargain.
Do you know if it mounts the drive into the "computer" or if it uses its own interface?
I'll likely try the trial.
300ddr
Postby 300ddr » 27.09.16, 02:35
It mounts in computer. But, it may have similar issues as FAT32/ExFAT with partition getting corrupt (the reason we stopped using this years ago, could be better now). Another option: moving files over network to the Mac from DE. Otherwise, move to NTFS drive, then read/copy on Mac to HFS (since Mac can read, but not write, to NTFS drives by default).
osity
Postby osity » 27.09.16, 05:41
Are you implying the mapping of a Macbook drive over TCP/IP on a PC? It seems I would still have to do two transfers. One to the Mac Drive then again to the clients destination Drive
Would be nice if Ace would make DE recognize HFS when saving from image files ...
Postby Amarbir[CDR-Labs] » 27.09.16, 10:11
300ddr wrote:Source of the post It mounts in computer. But, it may have similar issues as FAT32/ExFAT with partition getting corrupt (the reason we stopped using this years ago, could be better now). Another option: moving files over network to the Mac from DE. Otherwise, move to NTFS drive, then read/copy on Mac to HFS (since Mac can read, but not write, to NTFS drives by default).
Brian ,
If i Give Then Data in NTFS some People Still Complaint
osity
Postby osity » 27.09.16, 14:20
Amarbir,
Of course they complain about NTFS, that's the point of this conversation. We're discussing the easiest way to get it onto HFS+. If I was a Mac user I wouldn't want it on NTFS or exfat either.
There are limitations and potentials for corruption with those in a Mac Environment.
300ddr
Postby 300ddr » 27.09.16, 19:35
If you move the fies over the network onto an HFS drive (e.g. the customer's tranfer drive), then it's not NTFS it's Mac.
I think more importantly, Ace needs to make DeViewer Mac compatible so we can send file listings to Mac customers.
Postby digitalsupport » 27.09.16, 19:38
I set up a OSX workstation only job is copying data HFS+, Data Rescue on some cases plus handling fusion drives.
Would like to test PARAGON HFS+ for windows, from the specs it looks ok, has any one tested if DE can write to a mounted HFS+ partition directly ?
There is a 10 days try out version, so i just need to find som time to test.
lcoughey
Postby lcoughey » 27.09.16, 20:18
If cloned with DE with good file system, but bad sectors in files, we copy from DE to HFS+ formatted destination drive using MacDrive.
If file system is damaged, we move over to a Mac and use various recovery programs to recover directly to the HFS+ formatted destination.
If at all possible, we avoid copying to FAT32/exFAT formatted drives.
hipo
Postby hipo » 28.09.16, 07:13
Paragon HFS work great on Windows, mount HFS with write permissions. You can copy data direct from DE.
Sistrum Data Recovery
http://Www.datarecovery.mk
Postby digitalsupport » 28.09.16, 16:50
hipo wrote:Source of the post Paragon HFS work great on Windows, mount HFS with write permissions. You can copy data direct from DE.
Great will give it a go :)
Postby digitalsupport » 28.09.16, 21:59
+1 for Paragon HFS for windows. Just saved all data from HFS+ in DE to at HFS+ mounted in windows.
That will save some time and trouble in the future :)
osity
Postby osity » 29.09.16, 16:45
Paragon HFS eh?
Has anyone tried both Macdrive and Paragon HFS? How do they compare?
Thanks for the info, great thread!
thatdellguy
Postby thatdellguy » 30.09.16, 09:12
Huge +1 for Paragon HFS. Using it for several years now. We used MacDrive 7 and 8 before Paragon but it was super buggy. Paragon was cheaper, faster, less buggy, and took hardly any resources.
Return to “Data Extractor”
