Hi Folks,
Does anyone found a solution for a partial access problem yet?
I have a case here with a 2.5" HTS543232A7A384 drive.
It is identified and starts properly, and i can image good until 6%, then it is all bad UNC.
I cleared G-list and SAMRT but getting same result.
Some of the firmware modules are corrupted including PSHT(SEE LOG BELOW).
Did someone managed to solve a similar case?
Please advise,
Thanks Folks
Selected family......................... : 5432A7
Model by ID............................. : Hitachi HTS543232A7A384
Loading the table of "open" modules................................... : Ok
Test : Reading modules
Reading modules to profile folder (composite)
Folder: C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\HITACHI-IBM-ARM\5432A7\Hitachi HTS543232A7A384-ES2OA60W-E2434243HY6ANK-4\Data\Modules
Module RPSH............................. : Ok
Module USAG............................. : Ok
Module RAMI............................. : Ok
Error transferring command data: Reading SA [0x3F00000CA, 0x40]
Device error detected "UNC"
Error startintg command: Reading SA [0x3F0000105, 0x1]
Device error detected (UNC)
Error transferring command data: Reading SA [0x3F010010A, 0x40]
Error startintg command: Reading SA [0x3F0100126, 0x1]
Loading : RAM0, Code module........................................... : Ok
Module RAM0............................. : Ok
Error transferring command data: Reading SA [0x3F0001500, 0x40]
Error startintg command: Reading SA [0x3F0001521, 0x1]
Error transferring command data: Reading SA [0x3F0101540, 0x40]
Error startintg command: Reading SA [0x3F0101542, 0x1]
Error startintg command: Reading SA [0x3F0001773, 0x1]
Error startintg command: Reading SA [0x3F00019C5, 0x1]
Loading : PSHT, P-List module......................................... : Ok
Module PSHT............................. : Ok
Module RDMT............................. : Ok
Module RPOP............................. : Ok
Module SECI............................. : Ok
Module SECB............................. : Ok
Module ZONE............................. : Ok
Module SRVP............................. : Ok
Module SRVM............................. : Ok
Module CHNM............................. : Ok
Module IDNT............................. : Ok
Module SMRT............................. : Ok
Module SERL............................. : Ok
Module IOPS............................. : Ok
Module SSLD............................. : Ok
Module SCTH............................. : Ok
Module FEAT............................. : Ok
Module CNFG............................. : Ok
Module WWNM............................. : Ok
Module RPSP............................. : Ok
Module SPTR............................. : Ok
Module ABLP............................. : Ok
Module DBGC............................. : Ok
Module ALSM............................. : Ok
Module ATIR............................. : Ok
Module AVZN............................. : Ok
Module CGDF............................. : Ok
Module RDM1............................. : Ok
Module RDM2............................. : Ok
Error transferring command data: Reading SA [0x3F0002840, 0x40]
Error startintg command: Reading SA [0x3F000285C, 0x1]
Error................................................................. : Error startintg command: Reading SA [0x3F000285C, 0x1]
Loading : ELG1, Log module............................................ : Error
Module ELG1............................. : Error
Module EVLG............................. : Ok
Module PID1............................. : Ok
Module PID2............................. : Ok
Module PIDM............................. : Ok
Error................................................................. : Error startintg command: Reading SA [0x3F0001521, 0x1]
Loading : PDM1, P-List module (PDM1 - reference to PSHT).............. : Error
Module PDM1............................. : Error
Error................................................................. : Error startintg command: Reading SA [0x3F0101542, 0x1]
Loading : PDM2, P-List module (copy).................................. : Error
Module PDM2............................. : Error
Module HLR1............................. : Ok
Module HLR2............................. : Ok
Module MFGP............................. : Ok
Module AMPM............................. : Ok
Module MFGT............................. : Ok
Error transferring command data: Reading SA [0x3F0010700, 0x40]
Error startintg command: Reading SA [0x3F0010701, 0x1]
Error................................................................. : Error startintg command: Reading SA [0x3F0010701, 0x1]
Loading : DMP1, ...................................................... : Error
Module DMP1............................. : Error
Error transferring command data: Reading SA [0x3F00118C0, 0x40]
Error startintg command: Reading SA [0x3F00118E6, 0x1]
Error................................................................. : Error startintg command: Reading SA [0x3F00118E6, 0x1]
Loading : SDM1, ...................................................... : Error
Module SDM1............................. : Error
Error transferring command data: Reading SA [0x3F0012C00, 0x40]
Error startintg command: Reading SA [0x3F0012C3C, 0x1]
Error................................................................. : Error startintg command: Reading SA [0x3F0012C3C, 0x1]
Loading : SVLG, ...................................................... : Error
Module SVLG............................. : Error
Module DDD0............................. : Ok
Module DIAG............................. : Ok
Module WRT0............................. : Ok
Module WRT1............................. : Ok
Modules reading completed
HTS543232A7A384 with partial sector access
- odedshankar
Re: HTS543232A7A384 with partial sector access
Looks like you have a damaged P-List. Have you tried doing a software translator in Data Extractor? Or have you tried initializing translator in RAM through the utility?
- odedshankar
yep, it fails unfortunately.
Is there a way with these drives to reconstruct P-LIST?
Is it possible to image this disk from the end, backwards? As i understand you can acces the disk? If you use Winhex you can image from the end until the point it fails, than do the same from the beginning until the point it fails. Put both parts together and you can do your recovery. You will miss the missing piece.
I know it is not with ace's hard and software but perhaps a solution for your problem...
- odedshankar
hi dolab,
thanks for your suggestion, but there is not imaging beyond the first 6%.
Backwards or forward image will fail - it is a translator problem, and new translator can not be generated as the P-LIST 2 copies are corrupted.
odedshankar wrote:Source of the post Hi Folks,
Please advise,
Thanks Folks
Please Provide The Complete SA Backup Here On Forum i Would Like To Have a Look
- odedshankar
Here you go Aramabir:
https://dl.dropboxusercontent.com/u/495 ... 6ANK-4.rar
Take into consideration that the FW was read with ignoring reading errors otherwise nothing would have been possible to read.
