hello
i am beginner for data recovery services any one help this problem,
i have segatae 500dm002 kc45 fimware,
overlal error show,smart,alt list not erased show this error..
F3 T>m0,6,2,,,,,22
DiagError 0000500E Process Defect List Error
R/W Sense 00000002, R/W Error 841C0087, List Offset 00000000, List Index 00256177, File Error 000000D0
F3 T>
Executing user command.................. : Clear SMART
ASCII Diag mode
F3 T>/1
F3 1>N1
Failed to load overlay 00000004
Terminal : reply timeout error
ST500DM002 KC45 Failed to load overlay
Re: ST500DM002 KC45 Failed to load overlay
after try ace blog videos,sys file not read in terminal, i try different terminal baud rates but not read..
show this errors
F3 T>
Rd Sys File: vol = 3, FID = 01B, Copy = 000...
COM transfer baud rate set to 921600
Root Sys File Rd Err!
Rd Sys File: vol = 3, FID = 035, Copy = 000...
show this errors
F3 T>
Baud rate 921600 doesn't usually work in this family, but rate 921000 usually does. That having been said, an even lower rate might get a better read as it'll force the drive to slow down and might have a better chance at reading the file. By the way, did you check for NRG before trying translator regeneration?
Hello Lawrence,
Try to use loader for this drive.
Lawrence wrote:Source of the post Failed to load overlay 00000004
DataMedics wrote:Source of the post Baud rate 921600 doesn't usually work in this family, but rate 921000 usually does. That having been said, an even lower rate might get a better read as it'll force the drive to slow down and might have a better chance at reading the file. By the way, did you check for NRG before trying translator regeneration?
Jared ,
I Never Increase The Baud Rate Like This i am Sure I Am Not Creating a User Error Into It For No Reason .In Case NRG Is There How Do You Personally Approach The Case ?
Dmitriy_TS wrote:Source of the post Hello Lawrence,Lawrence wrote:Source of the post Failed to load overlay 00000004
Dimitry Sir ,
When Exactly Do You Need To Load a Loader ? . Specially In F3 Series Drives
