2060-771817-001 REV A -------- 1820
Regards.
List of compatible SATA PCB for 2,5" USB drives
- marcuscercal
Re: List of compatible SATA PCB for 2,5" USB drives
marcuscercal wrote:Source of the post 2060-771817-001 REV A -------- 1820
Do you mean, USB 771817------SATA 771820 ?
Hello Maxim ,
New Info From Myside
USB Board : 2060-771817-001 REV A
SATA Board : 2060-771820-000 Rev P1
The USB Was In a HDD Not Seen Much in India .The Model No is WD10TMVV-11TK7S2 "Helios " . I was able to read rom using toshiba adapter on the rx/tx/gnd pins using com port and powering it up via usb pord .Bare pcb only .People should remember it takes approx 15 minutes to go to kernel mode .So Please Be Patient That Time And Sit Back Remember Me and Have Coffee .
Thank you Amarbir[CDR-Labs], we will definitely remember you drinking the cofee and saving the data!
- digitalsupport
- User
A little tip to skip the coffee break is to connect power only to the USB connector and isolate hsa - do not connect it to a pc
digitalsupport wrote:Source of the post A little tip to skip the coffee break is to connect power only to the USB connector and isolate hsa - do not connect it to a pc
Pretty smart...why didn't I think of that? I guess I like coffee too much.
You can connect to a computer too, as long as you isolate the preamp so only the motor is spinning, then read ROM through terminal. Or just use boot ROM code. Always works for me.
DataMedics wrote:Source of the post You can connect to a computer too, as long as you isolate the preamp so only the motor is spinning, then read ROM through terminal. Or just use boot ROM code. Always works for me.
Jared ,
You did not get it it was a joke by Luke haa haa
- DDRecovery
I would like to add that 2060-771961-001 REV A and 2060-771959-000 REV P2 are mismatch. Hole of motor is too small, and screwholes are alligned differently. Controllerwise it looks like it could match, but physically it does not fit
It works though, just not a good physical fit. You just have to put in the three screws that do line up, and it'll work. I do this all the time.
- DDRecovery
It won't fit, really will not.. unless you take away some of the PCB material near the motor with a dremel. Maybe the drive i tried it on (WD10JMVW from 07Aug2014) is special, and has a wider motor then the ones you tried?
It's better to use a perfect fitting match like 2060-771933-000 REV P1 for 2060-771961-001 REV A boards, otherwise you will have to McGyver to make it fit.
Like I said, it works, just isn't an ideal fit. I do this about once or twice a week. Just lay it on there, put in the three screws that do line up, then go to town. It still makes contact in the right places for it to work, just isn't a snug fit and is a little bent.
DDRecovery wrote:Source of the post I would like to add that 2060-771961-001 REV A and 2060-771959-000 REV P2 are mismatch. Hole of motor is too small, and screwholes are alligned differently. Controllerwise it looks like it could match, but physically it does not fit
Hi ,
For Fitting we need to file some part of pcb around motor and then only 3 screws are necessary
Nope, no filing necessary. Here's a picture of that exact PCB on a case I just finished imaging on my bench:
As you can see the motor hole is too small, but you can still put in the three screws and it works perfectly fine. Trust me, I do this all the time and it works every single time. You're not seeing anything special that I haven't seen about 100 times.
Humm,
It works but By Using My Method It Settles Properly Thats All Dear Jared
