hello world,
In one of my case, I made a hot-swap on a WD6400BEVT.
I image the disk (a lot of black boxes, but 80% are OK)
Then I work on image only.
When I do a raw recovery, it found 30000 jpg files. Most of them are ok.
In explorer, I can't access to the main partition (Root Dir is not valid Operation aborted)
Scan MFT+IDX is poor help, main directory are missing
Search NTFS Structures is better, find almost all files...
I save them, size seems ok, but they are unreadable (corrupt files)
Do you have an explanation ? What can I do for this ?
thanks.
When I try on
files ok in RAW recovery, but invalid with structure
Re: files ok in RAW recovery, but invalid with structure
did you prepare donor properly with adaptives and correct translator? maybe you have shifts in data
Yes, I think so, it's the case we have discuss earlier monthes.
this modules have been transplanted : 31,36,03,40,41,42,43,49,4A,4D
you tell me 50 to 54 not important.
do i miss something ?
thks.
thks.
I will PM you with my Skype, you can add me and we can talk there, will be much easier
files found in lost+found directory, thanks to aj2008.
Thank you aj !
Thank you aj !
