Wd usb3
sepid
Wd usb3
Postby sepid » 31.08.14, 23:32
I have a USB drive -Western 500 usb3
Not identified
the terminal the Relo list i do clean (slow ....)
head test ok
And the translator regenetor would have chosen
No change was
Then I turned off SATA hard drive into the SATA mode to do things twice, but I did not change
What should I do.?
Maxim_TS
Re: Wd usb3
Postby Maxim_TS » 02.09.14, 15:47
Hello Sepid,
As far as I understood, you have soldered SATA adapter to patient PCB.
You need to use as short wires as it possible, in most cases it is critical.
What happening when you start the drive in SATA mode?
sepid
Re: Wd usb3
Postby sepid » 02.09.14, 17:30
when i hot-swap the hdd to sata, the disk detected and give ID full OK.
all of madules read correctly.
I do complex test and there is a lot Bad-Sectors in end of disk, (from 900000000 to end is Bad-Sector).
hdd not shown in Disk managment in Windows 7 when to conect usb.
Maxim_TS
Re: Wd usb3
Postby Maxim_TS » 03.09.14, 08:13
Hello Sepid,
First of all, you need to check heads in SATA mode, if they are good and able to write.
Then you need to check if Relo-List is really clean.
If the drive is not recognized in Windows via USB, the problem could be in PCB.
In this case you need to solder SATA adapter, and clone the drive via SATA.
sepid
Re: Wd usb3
Postby sepid » 03.09.14, 08:57
hi maxim
tanks for post
Do clone the any drive to the correct conclusion that
Or have the same drive?
Because I do not have the same drive
Maxim_TS
Re: Wd usb3
Postby Maxim_TS » 03.09.14, 09:42
Hello Sepid,
You can choose any drive with the same or more capacity.
Re: Wd usb3
Postby AJ2008 » 03.09.14, 10:38
If cloning to higher capacity you must cut LBA to same as patient as the key should be a certain distance from the end LBA
sepid
Re: Wd usb3
Postby sepid » 03.09.14, 11:28
sorry
i do 5g clone but no data recovery
data is encrypt !!
how data i can descrypt?
Re: Wd usb3
Postby AJ2008 » 04.09.14, 10:30
Did you read in reverse at all? Even 1% in reverse will be fine, this is more than enough to ensure key is read
sepid
Re: Wd usb3
Postby sepid » 04.09.14, 12:28
AJ2008 wrote:Did you read in reverse at all? Even 1% in reverse will be fine, this is more than enough to ensure key is read
i doing clone forward
now do half
but end sector (961380000) is bad sectors
sorry
i not know key? and how i can use key ?
Re: Wd usb3
Postby AJ2008 » 04.09.14, 13:22
Key can be found in module 25 or 38
What is the encryption controller?
sepid
Re: Wd usb3
Postby sepid » 04.09.14, 15:35
AJ2008 wrote:Key can be found in module 25 or 38
madule25
0x0000 52 4F 59 4C 01 00 30 00 25 00 01 01 21 49 0D 2D ROYL..0.%...!I.-
0x0010 30 30 31 30 30 30 30 55 07 07 07 00 00 00 00 00 0010000U........
madule 38
0x0000 52 4F 59 4C 01 00 30 00 38 00 01 01 32 55 8A C9 ROYL..0.8...2UŠÉ
Did you mean encryption contorol is chip an pcb?
if you mean there is symwave
Re: Wd usb3
Postby AJ2008 » 04.09.14, 17:10
Look in 242nd sector of module 38, you will see here 512 bytes of data that contains the key. This entire 512 bytes should be written to sector 976770435 of your image
sepid
Re: Wd usb3
Postby sepid » 04.09.14, 17:49
I'm very sorry, but how can i find the 242nd sector of madule 38? all lines is zero.
can i have your ID or yahoo or skype or ... to direct stablish with you?
thank a lot...
sepid
Re: Wd usb3
Postby sepid » 08.09.14, 20:51
hi aj 2008
how write to sector 976770435 madule 38 ?
tnx
Users browsing this forum: Bing [Bot] and 7 guests
