WD20EARS 60MVWB0 SA OK. head test OK But can't Read LBA .???
cuumaytinh
Postby cuumaytinh » 16.04.14, 10:02
SA test OK.
HEAD test OK.
but :
Translator regeneration
Regeneration method..................... : Use P-List only
P-List Copy 0........................... : Ok
P-List Copy 1........................... : Ok
Error Code : 3C15....................... : FMT PLIST PSN OUT OF RANGE
ROM:
ROM version............................. : 22.00E
ROM generation.......................... : 22.01E
Link table version...................... : 0B.36.
Consolidated ROM version................ : 00220000
ROM Modules:
Modules directory address............... : 377 654
Heads map............................... : 0,1,2,5,6,7
ROM Firmware version.................... : 00220000
Service area:
Permanent overlay....................... : Loaded
Heads test
Cylinder to test........................ : -100
Heads to test........................... : 0,1,2,5,6,7
Head 0.................................. : Ok
Head 1.................................. : Ok
Head 2.................................. : Ok
Head 5.................................. : Ok
Head 6.................................. : Ok
Head 7.................................. : Ok
any solution . thanks for alll
cuumaytinh
Re: WD20EARS 60MVWB0 SA OK. head test OK But can't Read LBA
Postby cuumaytinh » 16.04.14, 10:05
My P-list adn translation
GuideRecovery
Postby GuideRecovery » 16.04.14, 13:39
probably weak heads
did you try to image with selective heads
Wasim Zafar
https://mindmergepk.com
cuumaytinh
Postby cuumaytinh » 24.04.14, 08:56
GuideRecovery wrote:probably weak heads
Yes. i did !. But not works
GuideRecovery
Postby GuideRecovery » 26.04.14, 13:03
try changing the head map to 1,2,3,5,6,7 > soft reset and than change it back to original 0,1,2,5,6,7
see if it works
Wasim Zafar
Postby AJ2008 » 28.04.14, 14:13
Try to set all heads to '0' then after soft reset try to read sector with H0. If no success, repeat with '1'. Do this because it is impossible to see which head is damaged, and heads 0 + 1 are SA heads.
cuumaytinh
Postby cuumaytinh » 08.05.14, 17:47
i was change good head from donor HDA but . no thing change !! .
can by P-list Error ??
Postby AJ2008 » 09.05.14, 10:19
If translator is good then plist should not be so important. did you check all SA modules for any errors before you changed heads? does it ID well?
cuumaytinh
Postby cuumaytinh » 01.07.14, 04:51
AJ2008 wrote:If translator is good then plist should not be so important. did you check all SA modules for any errors before you changed heads? does it ID well?
But Transkator error .
now i want to translator regenator . But it show error.
i try . Write Module 33 (P-list) to Good donor driver and transtator regenator . But it same error .
I think problem at plist.
"Error Code : 3C15....................... : FMT PLIST PSN OUT OF RANGE"
or some address of sector in plist error ????????????????
