WD5000BEVT-60A0RT0 Shows BSY DRD DSC
Imnew
Postby Imnew » 09.12.13, 13:27
I have the above mentioned HDD. On power on DRD DSC ready. When running utility it shows BSY DRD DSC. Does not identify the HDD. Vibration and spinning is all right. There is no knocking. Please help how to recover data
asocla
Re: WD5000BEVT-60A0RT0 Shows BSY DRD DSC
Postby asocla » 09.12.13, 16:27
is ok your translator?
Postby AJ2008 » 10.12.13, 13:55
seems like slow responding fix needs to be run. When you load utility increase timeouts and be patient, I think utility will load correctly if you are patient
Imnew
Postby Imnew » 11.12.13, 07:59
Ok Thanks for the reply. I will try and inform.
