Toshiba MK6465GSX
pclab
Toshiba MK6465GSX
Postby pclab » 19.11.13, 20:29
I have this HDD which spins OK, no clicks and it goes Ready.
But If I try to ID it or something, it goes BSY.
Any Ideas? Can I do something by terminal?
dmarques
Re: Toshiba MK6465GSX
Postby dmarques » 26.11.13, 14:01
I have a solution for those.
Have you solved it?
pclab
Postby pclab » 26.11.13, 16:17
1. Isolate motor contacts on PCB; drive will be BSY; 2. Enter Toshiba utility; accept all prompts even though BSY; 3. Select Read MP RAM (Terminal) from SA menu; 4. Drive will come ready even though it's not spinning at this point; 5. Re-connect motor contacts on PCB; 6. Select Drive ID from appropriate menu; drive will now ID properly but is still not spinning; 7. Choose to re-calibrate drive; 8. Exit Toshiba utility and then re-enter it. Drive now spins up, IDs properly. Proceeded to erase G-list. Powered down drive. Re-powered.
dmarques
Postby dmarques » 26.11.13, 17:35
Good one 8)
waleed
Postby waleed » 27.11.13, 13:21
another easy way
power on then try id it will go busy . don't enter utility and leave it as it for some minuets it will not be busy .drd ,dsc and DRQ will be green . go for id and clear g list
houman_2h
Postby houman_2h » 31.12.13, 02:38
Isolate head contacts on pcb
Arihant
Postby Arihant » 13.08.14, 10:57
Good
Thanks,
Amit Shah
Arihant Data Recovery, India
Return to “Toshiba native”
