dear guru
hello
i have a usb3 hdd (it is firebird)
when i connect it through usb port , nothing happens
i can read all modules , Rom and tracks with com port
here is the spec:
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 4
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 1437
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 256 Kb
>ROM version............................. : 23.2HC
>ROM generation.......................... : 23.2JC
>Link table version...................... : TP.30.
>Consolidated ROM version................ : 0023002H
>ROM Modules:
>Flash ROM dir reading................... : Ok (Active)
>Flash ROM dir reading (Ext)............. : Ok
>Modules directory address............... : 69 093
>SA regions address...................... : by default
>SA Translator loading................... : Ok
!SA defects assigned..................... : 2
>Heads configuration..................... : by map
>Heads number in use..................... : 4
>Switched off heads...................... : No
>Heads map............................... : 0,1,2,3
>ROM Firmware version.................... : 0023002H
>Service area:
>Permanent overlay....................... : Loaded
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
>Configuration reading................... : Ok
>Master Password......................... : has not been set
>User Password........................... : has not been set
to recover the user data what I should I do next ?
best regards
Firebird USB3
- mojimorady
Firebird USB3
Mojtaba Morady
Data Recovery Expert
Data Recovery Eng. at CSSI
Re: Firebird SUB3
when you say nothing happens, what does this mean? Does it identify as a device within the system? Did you try to access it with anything? Are you presented with a Smartware window?
You need to write symptoms here, without symptoms it will be impossible to attempt to give any advice to you on it.
- mojimorady
Re: Firebird USB3
hi
nothing happens means that the host computer does not detect it , not in "disk management" nor the "Device Manager"
but thorough COM 3 port i was able to read all the Modules and Rom and SA tracks and in WD family window all the notification were shown as I mentioned .
I just tried with pc3000
best regards
best regards
Mojtaba Morady
Re: Firebird USB3
The device is receiving power and should show something in device manager, even if the HDD was defective. Because you can read via COM port, I guess there is something wrong with the USB connection or some element associated with it.
- mojimorady
Re: Firebird USB3
Dear AJ2008
you are right !!!
i tried "translator regeneration (use plist and glist (for data recovery ))
i connect the h.d.d to the computer using USB3 cable , in device manager , it is detected as " WD MY PASSPORT 0740 USB DEVICE "
good news is that this H.D.D is detected in disk management now but as an UNALLOCATED DRIVE PARTITION (it was not detected before in Disk Management) .
i tried in DE to recover data but it has lots of bad LBA ( in MAP sheet there are several black squares ) and it is very very slow .
any suggestion plz
best regards
you are right !!!
any suggestion plz
best regards
Mojtaba Morady
Re: Firebird USB3
If it is unstable you should not work with it under USB. Switch it to SATA.
If you continue to work with it as is over USB you will cause media to degrade further. You need proper diagnosis also, maybe your problem is bad or failing head(s).
