Arihant
Postby Arihant » 22.05.13, 09:02
Hi, I have one 7200.12 250gb HDD Remains busy. Terminal output shows
No HOST FIS-ReadyStatusFlags 2002A185 Error. Translator regenration, clear g-list , Clear smart command working fine.
Rst 0x08M
F3 T>m0,6,2,,,,,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 16, Max Certify Rewrite Retries = not supported
User Partition Format Successful - Elapsed Time 0 mins 00 secs
F3 T>
InitiateMarkPendingReallocateRequest for disc_lba: 00000000
InitiateMarkPendingReallocateRequest for disc_lba: 000001F4
InitiateMarkPendingReallocateRequest for disc_lba: 000001F5
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>/
F3 T>i4,1,22
F3 T>
ASCII Diag mode
F3 T>/1
F3 1>N1
Clear SMART is completed.
F3 1>
I have check with pcb change. but same Result Hdd remains busy.
F3 T>
ATA 15 Cmds
Ts(ms) dT(ms) Op Cnt LBA
0 99999999 00 0000 000000000000
0 0 00 0000 000000000000
RW 32 Cmds
Ts(ms) dT(ms) xT(ms) Type Option Mode St EC Info
33686607 99999999 100540424 02 005201 1000008 1 00000880 XFR WR USR LBA B 000055B6 L 00000408 BO 000000 BES 0061C25.1062024.0061C25
9304 4261289993 134217745 0A 001141 000000 9 01000080 FDB
778834 769530 4294905864 02 004849 000000 1 00000080 XFR CRT SYS TRK BO 000804 BES 006D800.006DCDF.006D800
717403 4294905865 968 02 00504D 000000 1 00000888 XFR WR SYS TRK BO 000000 BES 006D800.006DC7F.006D800
717411 8 200 02 081041 080000 1 001000C0 XFR WR SYS LBA B 00005F72 L 0000020B BO 080000 BES 0060800.006DCFF.006D800
1765484 1048073 4293919240 02 015045 800008 1 00400080 XFR WR SYS SEC BO 020020 BES 0079800.006DCFF.006D800
9171700 7406216 4286513032 02 005041 000000 1 000000C0 XFR WR SYS LBA B 00225F86 L 0010000A BO 000000 BES 006D000.006D4FF.006D800
717436 4286513032 4294950923 82 005041 000000 1 00800080
712837 4294962697 4616 42 005041 000000 1 00000080 SWD
2798221 2085384 4292881960 02 005043 000000 81 00000080 XFR WR SYS PBA BO E00000 BES 006D840.007DCFF.006D824
2814614 16393 4292870216 C2 005041 000002 1 000800C0
4911775 2097161 4290772999 06 805041 000002 1 000000B0 DITH
717030 4290772551 327625 12 005041 000090 1 00000080 TEMP 2426 degC
717487 457 8 23 004041 180000 1 000000A2 SRV_EC
712895 4294962704 4198395 02 005041 400000 1 00000080 XFR WR SYS LBA B 000060E8 L 00800001 BO 000000 BES 0160162.00601E1.0060162
1766075 1053180 4293918217 02 005049 000018 1 00400085 XFR WR SYS TRK BO 000008 BES 0060062.00601E1.0060162
717540 4293918761 4294934503 02 022241 000020 1 00000080 XFR RD SYS LBA B 000060A4 L 00020026 BO 010000 BES 0069800.006DAFF.006D802
4911307 4193767 4290773512 22 005049 000000 1 00000080 DL
701139 4290757128 4294950939 3B 105061 000000 1 00800080 SV_ALT
1733371 1032232 4293951466 06 205049 80000A 1 00800080 DITH
1209 4293235134 2704 2F 000000 000000 1 00000080 SPN_UP NORMAL
3913 2704 12 34 000000 000000 1 00000080 TCC 0
3925 12 25 02 002241 000000 1 00000080 XFR RD SYS LBA B 00000000 L 00000004 BO 000000 BES 00E9CF6.00E9EF5.00E9CF6
3951 26 3 02 002241 000000 1 00000080 XFR RD SYS LBA B 0001D682 L 00000001 BO 000000 BES 009B365.009B3E4.009B365
3954 3 5 02 002241 000000 1 00000080 XFR RD SYS LBA B 00000006 L 00000010 BO 000000 BES 00C1876.00C2075.00C1876
3959 5 10 02 002241 000000 1 00000080 XFR RD SYS LBA B 0000001A L 000000CA BO 000000 BES 00C1876.00C7D75.00C1876
3976 17 251 02 002241 000000 2 43110081 XFR RD SYS LBA B 000055EE L 00000001 BO 000000 BES 006ED80.006EDFF.006ED80
4227 251 2564 02 002241 000000 2 43110081 XFR RD SYS LBA B 000055EE L 00000001 BO 000000 BES 006ED80.006EDFF.006ED80
6791 2564 243 02 002241 000000 2 43110081 XFR RD SYS LBA B 0002B2A2 L 00000001 BO 000000 BES 006ED80.006EDFF.006ED80
7034 243 2564 02 002241 000000 2 43110081 XFR RD SYS LBA B 0002B2A2 L 00000001 BO 000000 BES 006ED80.006EDFF.006ED80
9601 2567 10 02 002241 000000 1 00000080 XFR RD SYS LBA B 00008A0C L 000000C8 BO 000000 BES 00620A5.00684A4.00620A5
9612 11 4 02 005041 000000 1 00000080 XFR WR SYS LBA B 000075AA L 00000001 BO 000000 BES 0061AA5.0061B24.0061AA5
ASCII Diag mode
F3 T>V4
Reassigned Sectors List
Entries: 0000, Retrieved: 0000, Alts: 0000, Removed: 0000, Pending: 0000, GList: 0000, RList: 0000
Idx LBA PBA LLLCHS of LBA PLPCHS of PBA SFI Hours Msecs Status BBM Mask
F3 T>V40
Nonresident GList 3 entries returned
Total entries available: 3
B4C1 1 20 12 0 8A1 DAA33
B4C4 1 20 12 0 8A4 DB057
B4C9 1 20 12 0 8A9 DBA2F
Thanks,
Amit shah
Thanks,
Amit Shah
Arihant Data Recovery, India
Filipp_TS
Re: No HOST FIS-ReadyStatusFlags 2002A185
Postby Filipp_TS » 22.05.13, 14:40
Hello, Arihant
Try next:
1. Check patient writing function.
2. Find a donor and copy from it to PC all modules.
3. Connect patient to PC3000 and try to read FID 093 then open 2A.rpm from donor and write it to patient HDD.
4. Re-turn power supply, re-launch utility.
In waiting for your reply.
Arihant
Postby Arihant » 23.05.13, 11:35
1. Check patient writing function. ---> Writing Possible
2. Find a donor and copy from it to PC all modules. ---> done
3. Connect patient to PC3000 and try to read FID 093 then open 2A.rpm from donor and write it to patient HDD. ---> Write sucessfully
Same Result. - Remains busy. Terminal output is
Rst 0x08M
F3 T>V4
F3 T>V40
Total entries available: 0
Thanks,
Thanks,
Amit Shah
Filipp_TS
Postby Filipp_TS » 23.05.13, 16:16
Then try to perform "translator regeneration".
waiting for your reply (don't forget to attach a log)
Arihant
Postby Arihant » 24.05.13, 07:32
Regenerate translator done successfully.
After Power on/ off. Now the hdd is continually clicking. Motor does not spin stop. Terminal shows only Rst 0x80. I can't get terminal T> Prompt.
Thanks,
Thanks,
Amit Shah
Filipp_TS
Postby Filipp_TS » 24.05.13, 08:11
Try to ger access to terminal.
for it:
1. isolate PCB from HDA in spindle contact place, after few minute it is Ready.
2. remove isolator and return back PCB to HDA.
3. Try to get access to terminal
4. perform /U for run spindle.
p.s. Do you switch off ticks in "Edit HDD ID" ?
Arihant
Postby Arihant » 24.05.13, 08:45
Yes I have got the terminal access. Still HDD Remains busy. I can't Read the Hdd Id page. Show I can't Switch off the ticks.
Thanks,
Thanks,
Amit Shah
Filipp_TS
Postby Filipp_TS » 24.05.13, 09:15
You can open "Edit HDD ID" page:
1. Tests -> Service information -> Work with Servise area -> Edit HDD ID
or
2. Tools -> Utility extensions -> View and edit HDD resources.
Goto "System file" tab and find next:
Volume 0x00 File ID 0x0093
After that shows window Edit HDD ID.
You need to switch off all ticks except "Show additional diag msg in terminal", "Media Cache" and "Switch HDD power on\off before saving"
and press OK.
Arihant
Postby Arihant » 24.05.13, 09:36
Filipp wrote:You can open "Edit HDD ID" page:
1. Tests -> Service information -> Work with Servise area -> Edit HDD ID ---> Can't Access.
or
Volume 0x00 File ID 0x0093 ---> This command does not display contains. After that Head is Clicking.
After that shows window Edit HDD ID. -
and press OK.
Thanks,
Amit Shah
Filipp_TS
Postby Filipp_TS » 24.05.13, 10:31
Pls, see at PM messages..
Arihant
Postby Arihant » 24.05.13, 13:15
Filipp wrote:Pls, see at PM messages..
Thanks,
Amit Shah
Arihant
Postby Arihant » 24.05.13, 17:06
I have Open 35id. It's First two bytes are already Zero. So I have not updated the smart. After that Translator regenration run sucessfully.
Power off /on. Hdd shows same
Rst 0x08M
No HOST FIS-ReadyStatusFlags 2002A185. Now Hdd is not clicking. Remain busy.
Thanks,
Thanks,
Amit Shah
Filipp_TS
Postby Filipp_TS » 24.05.13, 17:30
Try to do follow steps:
Perform in terminal r346 and see what happen.
don't forget to attach a report.
Waiting for you reply.
Arihant
Postby Arihant » 28.05.13, 06:10
Filipp wrote:Try to do follow steps:
r346 gives diagerror 24.
Rst 0x08M
ASCII Diag mode
F3 T>
F3 T>r346
DiagError 00000024
Thanks,
Thanks,
Amit Shah
