WD WD5000BMVV-11SXZS1 USB drive, reads SA but no user data
narro
Postby narro » 25.04.12, 00:44
hi
i have a WD5000BMVV-11SXZS1 USB drive with PCB problem, i changed ROM chips and now i can read all modules at SA area without errors. I've made translator regeneration, Glist erase, Smart Erase with no problems but drive still don´t have access to user data.
DE is able to recognize the drive and its parameters like model, fw, capacity, s/n, but when i click on LBA 0 i get a black block
Do you have any idea about this drive? any experience would help.
Best Regards
Re: WD WD5000BMVV-11SXZS1 USB drive, reads SA but no user da
Postby ACE_Admin » 28.04.12, 10:59
This is a Helios WD Drive.
Well, try to querry 2nd and other sectors. It can happen there is a read bad block.
If it isn't possible to get anything from this drive, I advise you to get a donor
i changed ROM chips
Can you explain , do you have a donor drive? Maybe there is some difference between patient and donor boards. Please explain.
Waiting for your reply.
300ddr
Postby 300ddr » 29.04.12, 03:51
royl slow fix? (i.e. check mod 32)
Postby AJ2008 » 09.05.12, 10:57
Sounds like one or more head has error which stops translation system loading completely.
Did you try head map edit in RAM?
