WD Zeus and Hulk. Healthy SA - but no access to surface
DR_Ireland
Re: WD Zeus and Hulk. Healthy SA - but no access to surface
Postby DR_Ireland » 09.10.09, 11:46
The same problem with Hulk drive.
SA backup here:
http://www.mediafire.com/?sharekey=f693 ... f6e8ebb871
DR_Ireland
Postby DR_Ireland » 28.10.09, 12:46
Edited "RAM Head map" and found Head7 failing. Imaged using all remaining heads and got most of the data except for movies. This problem is not firmware-related, looks like due to one (or more) failing heads the Translator is not being loaded properly. Head Test in this drive family is not reliable.
Vikas
Postby Vikas » 15.02.12, 07:58
I have Kermit and I found it has a head issue. RAM head mapping works perfectly.
Vikas
Postby Amarbir[CDR-Labs] » 18.03.12, 07:37
Vikas wrote:I have Kermit and I found it has a head issue. RAM head mapping works perfectly.
Vikas
Humm ,
disabling The Head Seems To work in some cases
DataSector
Postby DataSector » 27.04.12, 14:09
I had same problem with WD1600BEVS-08RST2 (Aries family), SA ok but no acces to user data, no single sector...
All heads ok...
At the end it turns out that read/write chanel was dead. Changed PCB and get all user data...
einstein9
Postby einstein9 » 28.04.12, 20:48
sarmich15 wrote:Was anyone able to fix this problem? We have got a couple of 1TB Hulks with the exact same symptoms...
Thanks a lot!
the problem is else where my dear, i got many of those and managed to get the data out of it.
drdoc
kermit WDC WD10EAVS-00D7B1 - bad head 7
Postby drdoc » 07.06.12, 04:59
I have kermit
Model : WDC WD10EAVS-00D7B1
Serial : WD-WCAU43706997
Firmware : 01.01A01
Capacity : 931.51 GB (1 953 525 168)
sa test good
heads test good
sounds good
cant read anything - gets abrts
editted ram head map and turned off head 7, sw reset, drive comes ready (as before) but now I can read.
I imaged drive using remaining heads.
Is there a way to turn head 7 back on?
If I edit in ram will the head remain on if I dont do sw reset?
Head test works on head 7
If I go read cyl -10 head 7 I see A7 A7 which is the pattern written by head test.
So it works.
Any solution short of head swap?
skype: wayne_horner
Alandata Data Recovery
Postby AJ2008 » 07.06.12, 10:02
What are JOG values and DAC values for all the heads?
cuumaytinh
Postby cuumaytinh » 24.04.14, 08:55
WD20EARS. Is same problem.
when translation it show : Error Code : 3C15....................... : FMT PLIST PSN OUT OF RANGE
i think. P-list has error .
I was change head but not work.
i trying . i will shows for all
