The same problem with Hulk drive.
SA backup here:
http://www.mediafire.com/?sharekey=f693 ... f6e8ebb871
WD Zeus and Hulk. Healthy SA - but no access to surface
- DR_Ireland
- DR_Ireland
Re: WD Zeus and Hulk. Healthy SA - but no access to surface
Edited "RAM Head map" and found Head7 failing. Imaged using all remaining heads and got most of the data except for movies. This problem is not firmware-related, looks like due to one (or more) failing heads the Translator is not being loaded properly. Head Test in this drive family is not reliable.
I have Kermit and I found it has a head issue. RAM head mapping works perfectly.
Vikas
Vikas
Vikas Seth
Data Track System
http://www.datatracksystem.net
http://www.facebook.com/datatracksystem.net
Data Track System
Vikas wrote:I have Kermit and I found it has a head issue. RAM head mapping works perfectly.
Vikas
Humm ,
disabling The Head Seems To work in some cases
- DataSector
I had same problem with WD1600BEVS-08RST2 (Aries family), SA ok but no acces to user data, no single sector...
All heads ok...
At the end it turns out that read/write chanel was dead. Changed PCB and get all user data...
All heads ok...
sarmich15 wrote:Was anyone able to fix this problem? We have got a couple of 1TB Hulks with the exact same symptoms...
Thanks a lot!
the problem is else where my dear, i got many of those and managed to get the data out of it.
kermit WDC WD10EAVS-00D7B1 - bad head 7
I have kermit
Model : WDC WD10EAVS-00D7B1
Serial : WD-WCAU43706997
Firmware : 01.01A01
Capacity : 931.51 GB (1 953 525 168)
sa test good
heads test good
sounds good
cant read anything - gets abrts
editted ram head map and turned off head 7, sw reset, drive comes ready (as before) but now I can read.
I imaged drive using remaining heads.
Is there a way to turn head 7 back on?
If I edit in ram will the head remain on if I dont do sw reset?
Head test works on head 7
If I go read cyl -10 head 7 I see A7 A7 which is the pattern written by head test.
So it works.
Any solution short of head swap?
Firmware : 01.01A01
sa test good
heads test good
sounds good
So it works.
skype: wayne_horner
Alandata Data Recovery
What are JOG values and DAC values for all the heads?
- cuumaytinh
WD20EARS. Is same problem.
when translation it show : Error Code : 3C15....................... : FMT PLIST PSN OUT OF RANGE
i think. P-list has error .
I was change head but not work.
i trying . i will shows for all
