Seagate Green ST2000DL003 CC45
Towerrat79
Postby Towerrat79 » 05.08.11, 13:05
Greetings
The Seagate drive will not correctly identify itself. Entering the Utility I manually choose the Barracuda 7200.12, and start the utility. I receive the error HDD ID has not been read.., select Yes and the utility opens. The following lights are on DRD, DSC, and DRQ a soft reset will set the lights to BRD and DSC. But it will not read the hard drive model, Serial..
Running the Utility the hard drive is not recognized but the drive spins up, there is no clicking sound, and the log screen shows
Model : HDD ID has not been read
Serial :
Firmware :
Capacity : .49 MB (1 000)
Current utility options are outdated!
Loading default settings!
Then press OK!
Tech Key...
Drive not ready
I switch to the Terminal Tab, power off the drive and then power it on, I receive the following message:
(note: the last section repeats itself (DOS) Write Failure....)
Rst 0x40M
MC Internal LPC Process
(P) SATA Reset
User Data Base 0098F860
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 4011A58C 4011869C
Seg Write Preamble VBM start: 000010A7 end: 000010CE
Footer - start: 000010D0 end: 000010F7
Seg Read Preamble VBM - start: 000010F9 end: 00001120
Footer - start: 00001122 end: 00001149
Nonvolatile MCMT sequence number 000033F1
[RSRS] 09A1
Starting LBA of RW Request=0005440C Length=000004EC
ProcessRWError -Read- at LBA 00054482 Sense Code=43110081
InitiateMarkPendingReallocateRequest for disc_lba: 00054482!
Reconstruction: EXCEPTION: Seg Read Fail: Status = 0000
ErrorSegmentOffset = 03B0
Status = 0001
Footer Obtained: D0D0CAFE 000009C3
Continuing after error
Reconstruction: EXCEPTION: Segment Overall Sequence Number Mismatch
000033D9 000009C3
Recon Last Chance Header ID D0D0CAFE SeqNum 000009C4 Current Segment, Head 09A1 09A1
[MCMTWS]
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00005141
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000002A
MCMainPOR: MCStateFlags = 00005141
MCMainPOR: Feature Enabled...
[SR] 0000
(DOS)ATI NEED: 0x00167059 - 0x00167191 00000290 - 0x00000292
(DOS) Write Error
(DOS) Write Failure Reallocation started.
(DOS) AutoWriteReallocationEnabled and Reallocation Request Issued. !84320091
(DOS) WriteFailureReallocateLBARequest is executed successfully.
(DOS) Write Error
Eventually the drive will show BRD and DSC, but when I try to read the Hard Drive ID the lights change to BSY, BRD and DSC.
At times the drive will show the correct model number
Model : ST2000DL003-9VT166
Serial : 5YD3WHQC
Firmware : CC45
Capacity : 1 863.02 GB (3 907 029 168)
Has anyone come across this error?
Frank
Igor
Re: Seagate Green ST2000DL003 CC45
Postby Igor » 09.08.11, 09:03
Sometimes the problem may be solved by SMART/Glist clearing or translator regenerating.
Do you have terminal access? To check it, restart power and immediately press many times CTRL+Z.
If F3T> will appear try to clear smart and restart power. If behavior will be the same, try to clear Glist.
If Glist clearing will not help also, try to make next steps:
Get terminal access
Go to 7 level
Type
F3 7>m100 - press enter
Paste here all logs.
Also write please more detailed about
"At times the drive will show the correct model number
Serial : 5YD3WHQC
Firmware : CC45
Capacity : 1 863.02 GB (3 907 029 168)"
When does it show full ID and what error do you get if you try to read user sectors at that time?
Towerrat79
Postby Towerrat79 » 09.08.11, 11:44
Hello Igor, thank you for the reply
Firstly the section "At times the drive will show the correct model number" In the Utility Section, I would power on the drive, quickly Press the Run Utility Button (before BSY Light was off), sometimes the drive would display the model number. If I waited for the drive to not be busy, then I would get the generic Capacity: .49 (1 000) model information.
On to your recommendation.
I cleared the SMART/GLIST as well as went to terminal mode 7 and inputted m100 (Please see file Terminal_log.log)
After the above process, in the Utility Section, I would turn the power on to the drive, and then run the utility. The Utilty would find the correct drive number 7200.12 and I would received the messages in the attachments. When I tried to read the CP again, I received the error
LED: 000000EE and the drive remained BSY
Using DE, I attempted to access the customers data.
The initial window of DE would open after map creation and Preliminary Filling in were accomplished. I then selected the Explorer button and after a short time the following Registers were lite: DRD DSC ERR and UNC No file structure was displayed in the results.
I did not do the translator regeneration yet, but will await your response from the above information.
Frank
Igor
Postby Igor » 09.08.11, 13:57
Try to perform next steps (you will need newest version of utility):
turn power on
immediately run utility
utility should be initialized properly
restart power again and immediately go to "Work with SA" - "HDD ID editing"
uncheck all checkboxes except first one "Show additional diag msg in terminal" and check "Switch HDD power supply OFF/ON before saving"
HDD ID editing.JPG (31.47 KiB) Viewed 13418 times
Press OK.
Towerrat79
Postby Towerrat79 » 09.08.11, 14:23
Completed, I tried to attach the log as a .txt and .log and received the error The Extension ... is not allowed??
Rst 0x40M
(P) SATA Reset
RAW OFF
PASS
User Data Base 0098F540
MCMainPOR: Start:
Nonvolatile MCMT sequence number 00003442
[RSRS] 09A1
ProcessRWError -Read- at LBA 00054482 Sense Code=40000087
Status = 0001
000033D9 000009C3
[MCMTWS]
[SR] 0000
Igor
Postby Igor » 09.08.11, 14:30
I can not see any log and
are there some changes in behavior?
Did procedure go smoothly?
Towerrat79
Postby Towerrat79 » 09.08.11, 14:41
Hi Igor
I had to paste the results into the text box, for I could not attach a document. I was able to accomplish the HD ID Editing without a problem. The hard drive spins up, and reports its status as DRD DSC. In the utility the drive seems to be OK. In DE I still get the errors DRD DSC ERR and UNC. They stay lit
Do you want me to regenerate the translator now?
Igor
Postby Igor » 09.08.11, 15:11
Can you create head map in DE? If so, check reading by each head separately.
As I understand you can see proper ID in utility always. Right?
Can you save SA modules now?
Can you read user sectors via sector editor in Seagate F3 utility?
Towerrat79
Postby Towerrat79 » 09.08.11, 18:28
I could create the head map in DE; however, all of the heads (one at a time) produced failures. DRD DSC ERR and UNC.
I can see the proper hard drive information and all of the information is correct.
I can and have saved the SA Modules, but I continually receive errors when I try to save the SA CP modules.
CP Files individually I can read all except 000A, 000F, 0010, 0012
When I try to use the Sector Editor in the utility I receive a popup error Read Error (48-bit) readiness timeout (1000)ms.
Towerrat79
Postby Towerrat79 » 10.08.11, 09:48
Hi Igor
When working on this drive within the utility, I receive the following messages in red:
BGD15D.CCD4.AACT00.CC45
Firstly, what do they mean and how do I fix this error?
Igor
Postby Igor » 10.08.11, 12:59
Towerrat79 wrote:Hi Igor
It means that utility options are outdated :)
To solve it, run utility, go tools - options, press on the button "Seagate F3 architecture... ", press OK (do not change anything), and OK one more time. Restart utility. Utility options will be updated.
Igor
Postby Igor » 10.08.11, 13:00
Towerrat79 wrote:I could create the head map in DE; however, all of the heads (one at a time) produced failures. DRD DSC ERR and UNC.
Try to regenerate translator.
Towerrat79
Postby Towerrat79 » 10.08.11, 14:08
Regenerated Translator Result OK
Tried to use Sector Edit (read only) Sector 0, 63 received Read Error (48 bit) device error detected (UNC) with DRD DSC ERR and UNC lit. Soft reset and the drive went back to ready DRD and DSC.
Igor
Postby Igor » 10.08.11, 16:31
What about sectors in the middle and in the end of the disk? Are they readable?
Run command "Show User Track Slip List" from user commands menu and attach here log of the reading. You can attach it in RAR file.
Towerrat79
Postby Towerrat79 » 10.08.11, 16:59
I receive the same error through out the drive. I ran Show User Track Slip List as requested and the results are attached. I looked around further and it does not appear that the SMART was cleared. I tried a couple of times; however, attached is the result when I reviewed it after clearing it.
smart.rar
Smart Log change extension to .txt
(2.62 KiB) Downloaded 630 times
Show User Track Slip List.rar
(198.97 KiB) Downloaded 502 times
