ST2000DL003 FIRMWARE PROBLEM
OHMYDATA
Postby OHMYDATA » 03.05.11, 09:02
i have a ST2000DL003 with FW CC31 firmware failed like a Baracuda 11.
Not detect in bios but normal sound.
I tried to fix with hyper terminal but fail.
Please help.
dmarques
Re: ST2000DL003 FIRMWARE PROBLEM
Postby dmarques » 03.05.11, 09:30
Never seen that drive.
Is that the model? And what's the family?
Can you post a picture of the label?
OHMYDATA
Postby OHMYDATA » 03.05.11, 10:22
Please refer attached picture.
dmarques
Postby dmarques » 04.05.11, 18:07
Now I see it. LP series.
Can you shows terminal log?
einstein9
Postby einstein9 » 04.05.11, 22:42
what is the problem with this drive?
and when it powers up, does the sound looks OK or clicks?
again some terminal log of the Init. from termianl
OHMYDATA
Postby OHMYDATA » 12.05.11, 03:32
Capacity 0 MB problem.
After power on, sounds ok.
OHMYDATA
Postby OHMYDATA » 13.05.11, 09:32
Shows terminal log:
Rst 0x40M
MC Internal LPC Process
(P) SATA Reset
User Data Base 009907F0
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 4011985C 4011796C
Seg Write Preamble VBM start: 000010A7 end: 000010CE
Footer - start: 000010D0 end: 000010F7
Seg Read Preamble VBM - start: 000010F9 end: 00001120
Footer - start: 00001122 end: 00001149
Nonvolatile MCMT sequence number 00006299
[RSRS] 1D74
Reconstruction: EXCEPTION: Segment Overall Sequence Number Mismatch
00003219 00000000
[MCMTWS]
Reconstruction Fail: Burly Case
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00001001
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000002A
MCMainPOR: MCStateFlags = 00001001
MCMainPOR: Feature Disabled...
No HOST FIS-ReadyStatusFlags 0002A1E1
ASCII Diag mode
OHMYDATA
Postby OHMYDATA » 13.05.11, 09:33
Shows terminal log:
Rst 0x40M
(P) SATA Reset
MCMainPOR: Start:
[RSRS] 1D74
00003219 00000000
[MCMTWS]
ASCII Diag mode
dmarques
Postby dmarques » 13.05.11, 13:15
What fixes did you apply already and what was the results?
OHMYDATA
Postby OHMYDATA » 14.05.11, 03:26
Clear smart
T>/1
1>N1
Clear defect list & translator regenerate.
T>i4,1,22
T>m0,6,2,,,,,22
But keeps bsy.
einstein9
Postby einstein9 » 20.05.11, 20:16
when you power it ON, just listen carefully and listen
does it spin normal? on the begin. ???
OHMYDATA
Postby OHMYDATA » 28.05.11, 05:02
Yes, it spins normal.
einstein9
Postby einstein9 » 28.05.11, 10:12
both clearing smart & translator reg. were ok or with problems?
OHMYDATA
Postby OHMYDATA » 31.05.11, 02:46
It works with no error.
