Seagate barracuda Antipending solution
sempre
Postby sempre » 20.10.10, 15:55
LOG TERMINAL
Reset
4096k x 16 DRAM
GALAXY - 1_Disk S-6B 08-30-06_15:36
HM SFI
(P)PATA Reset
Master
AT Er 00 Nwt Er 43 RdWr 0eced.00.0000
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot: 97f29ff7 b6 97f29ff7.1.840 0000 005f 0000 0000
DiskAccess ReadSector EC=43 at 00eced.00.0000
CE Log ErrCode=43 LBA=f2210fd Type=5 Add To Pending f2210fd
AT Er 00 Nwt Er 43 RdWr 0eced.00.0001
Niwot: 9ff79ff7 b6 9ff79ff7.1.840 0000 005f 0000 0000
CE Log ErrCode=43 LBA=f2210fe Type=4 Remove from Pending f2210fe
AT Er 00 Nwt Er 43 RdWr 0eced.00.0002
DiskAccess ReadSector EC=43 at 00eced.00.0002
CE Log ErrCode=43 LBA=f2210ff Type=5 Add To Pending f2210ff
AT Er 00 Nwt Er 43 RdWr 0eced.00.0006
DiskAccess ReadSector EC=43 at 00eced.00.0006
CE Log ErrCode=43 LBA=f221103 Type=5 Add To Pending f221103
AT Er 00 Nwt Er 43 RdWr 0eced.00.000c
DiskAccess ReadSector EC=43 at 00eced.00.000c
CE Log ErrCode=43 LBA=f221109 Type=5 Add To Pending f221109
AT Er 00 Nwt Er 43 RdWr 0eced.00.000f
DiskAccess ReadSector EC=43 at 00eced.00.000f
CE Log ErrCode=43 LBA=f22110c Type=5 Add To Pending f22110c
AT Er 00 Nwt Er 47 RdWr 0eced.00.0014
DiskAccess ReadSector EC=43 at 00eced.00.0014
In pages 18, 19 (11.2.4.11) MANUAL PC3K is help,
Not enough help ...
Can anyone detail the actions the utility and DE?
nothing is impossible!
sempre
Re: GALAXY2D
Postby sempre » 20.10.10, 18:47
by the data extractor is very very slow but the copy!
Does anyone here have any solution to make this copy be faster?
:mrgreen:
Igor
Re: GALAXY2D
Postby Igor » 21.10.10, 09:43
You should create loader with next options
Then run DE with next options
Choose HDD initialization and APP modifications for ATA
Then select loader saved before
And try to make an image.
rms620
Re: GALAXY2D
Postby rms620 » 24.10.10, 14:05
Thanks Igor...I had same problem....it is great
Nick_CT
Re: Seagate barracuda Antipending solution
Postby Nick_CT » 09.03.11, 10:59
I had the problem below and it solved it, is a good solution :) Thanks Igor.
Reset
4096k x 32 DRAM
GALAXY - 1_Disk S-6D 09-22-06_15:48
Buzz HM SFI
(P)PATA Reset
Master
$SFI
AMR
AT Er 00 Nwt Er 43 RdWr 1ce3d.03.0187
Niwot: 97f29ff7 b6 97f29ff7.3.640 0000 005f 0000 0000
DiskAccess ReadSector EC=43 at 01ce3d.03.0187
CE Log ErrCode=43 LBA=24626af0 Type=5 Add To Pending 24626af0
$$$SFI
AMR
CorrectWriteStart
AT Er 00 Nwt Er 1b RdWr 1ce3d.03.0186
Niwot: 24626969 14 24626969.2.030 0187 3642 0187 0000
Spare of 24626aef failed
AT Er 00 Nwt Er 43 RdWr 1ce3d.03.0188
Niwot: 9ff79ff7 b6 9ff79ff7.3.640 0000 005f 0000 0000
DiskAccess ReadSector EC=43 at 01ce3d.03.0188
CE Log ErrCode=43 LBA=24626af1 Type=5 Add To Pending 24626af1
$$$SFI
AMR
AT Er 00 Nwt Er 47 RdWr 1ce3d.03.0189
DiskAccess ReadSector EC=47 at 01ce3d.03.0189
CE Log ErrCode=47 LBA=24626af2 Type=5 Add To Pending 24626af2
$$$SFI
AMR
AT Er 00 Nwt Er 43 RdWr 1ce3d.03.018a
CE Log ErrCode=43 LBA=24626af3 Type=4 Remove from Pending 24626af3
CorrectWriteStart
AT Er 00 Nwt Er 1b RdWr 1ce3d.03.018a
Niwot: 24626af3 14 24626af3.2.030 0001 3642 0001 0000
Spare of 24626af3 failed
CorrectWriteStart
AT Er 00 Nwt Er 1b RdWr 1ce3d.03.018b
Niwot: 24626af4 14 24626af4.2.030 01c9 3642 01c9 0000
Spare of 24626af4 failed
CorrectWriteStart
AT Er 00 Nwt Er 1b RdWr 1ce3d.03.018c
Niwot: 24626af5 14 24626af5.2.030 01c8 3643 01c8 0000
Spare of 24626af5 failed
CorrectWriteStart
AT Er 00 Nwt Er 1b RdWr 1ce3d.03.018d
Niwot: 24626af6 14 24626af6.2.030 01c7 3644 01c7 0000
Spare of 24626af6 failed
CorrectWriteStart
AT Er 00 Nwt Er 1b RdWr 1ce3d.03.018e
Niwot: 24626af7 14 24626af7.2.030 01c6 3645 01c6 0000
Spare of 24626af7 failed
CE Log ErrCode=43 LBA=24626969 Type=6a$$$SFI
AMR
AT Er 00 Nwt Er 43 RdWr 1ce3e.03.0104
Niwot: 97f29ff7 b6 97f29ff7.3.640 0000 005f 0000 006a
DiskAccess ReadSector EC=43 at 01ce3e.03.0104
CE Log ErrCode=43 LBA=24626dc1 Type=5 Add To Pending 24626dc1
$$$SFI
AMR
hassan
Postby hassan » 23.05.11, 16:38
Thank you Igor
I can get all data buy using this method
Nadpc3k
Postby Nadpc3k » 11.08.12, 22:01
I have ST 375000640AS ... i tried this solution ... it goes fine until at the end when it says ,, cmd 4A, PARMAS it stays at this command for a big while and then errors " cannot start app code " ... why any solution ?
labtech
Postby labtech » 22.08.12, 19:32
If you create a new test task and attempt a new image of the source drive, does the image process still go well like you said until the end?
I suspect not.
Postby AJ2008 » 23.08.12, 10:16
labtech wrote:If you create a new test task and attempt a new image of the source drive, does the image process still go well like you said until the end?
I suspect not.
I think "fine until the end" is referring to the actual loading of LDR during task creation...
labtech
Postby labtech » 28.08.12, 17:25
I suspect not.
I guess you are right.
Need to read loader from a file and not from the drive. Hopefully that will work.
Nicso
Postby Nicso » 18.02.13, 20:06
I have the same problem with ST37506440AS and the solution say "can't start app..."
Are news in this topic?
Nicso
labtech
Postby labtech » 09.04.13, 16:55
Are you using a loader?
hhddrec
Postby hhddrec » 17.05.13, 17:46
Can anyguy here explain if is posible to resolve this slow reading without DE
I only have PC3K UDMA
Postby AJ2008 » 17.05.13, 17:50
hhddrec wrote:Can anyguy here explain if is posible to resolve this slow reading without DE
It is, but only with risks of totally 'bricking' the hdd. Often, if there are errors at SA, attempts to rebuild CERT will fail and data will not be accessible.
Personally, I would invest in a DE to accompany your PC3000.
hhddrec
Postby hhddrec » 17.05.13, 18:52
can you show me this other way?
Data is not very important
Thanks in advanced
Return to “Arch ST10”
