Hi all
it seems that i can't get an access to the SA, the PC3k utility reads:
Techno mode key
RAM:
Zone allocation table................... : HDDs RAM reading error Techno CMD sending error Device Error Detected: "VSCE PERM OVL NOT LOADED"
SA SPT.................................. : 1311
Head number reading..................... : Ok
ROM:
ROM version............................. : 05.ARE
ROM generation.......................... : 05.ARE
Link table version...................... : 04.AD.
Head map................................ : 0,1
Firmware version........................ : 00010000
Service area:
SA dir reading.......................... : Ok
SA Copies avalabled..................... : NONE
Configuration reading................... : No SA copy avalabled
i can read the rom, the heads doesnt knock, heads test is fine, seems like the system area is not accessible or damaged.
i would apretiate any help you can give me on this topic.
wd3200aaks-00b3a0
Re: wd3200aaks-00b3a0
Is this PCB native PCB, or donor?
I think your drive will detect as zero capacity... with no serial number.
I got such problem before after change head. drive Got ready no knock but No ID and No S/N... if you have Donor Drive.. perform Hotswap and see if you can access SA or not.. if Not it is head allignment issued....
steven wrote:I think your drive will detect as zero capacity... with no serial number.
indeed, the only thing that the utility can detect is the drive's family. Still, it's a rather weird situation - the heads test is fine, the rom seems to be ok too, the drive doesn't knock and steel i can't get no access to the SA zone. Think that HotSwap will help?
I am not sure if HotSwap will help. Do you know the source of the problem? I have recieved several WD drives with simialr fault that have been dropped, and I believe this drop has damaged or modified the alignment.
The client claims that the disk suffered from electirc shortage, but i cannot be sure of it
pls let us know the progress.....
Did you try to read modules by ID? I had this problems more than once, it was a firmware problem. With UDMA you can solve it.
Got the same problem except mine is L9 instead of B3
Anyone know how to solve this problem?
Thank you
Thank you
Can you read SA Tracks except -1?
