wd3200aaks-00b3a0
ilia
wd3200aaks-00b3a0
Postby ilia » 05.05.09, 11:33
Hi all
it seems that i can't get an access to the SA, the PC3k utility reads:
Techno mode key
RAM:
Zone allocation table................... : HDDs RAM reading error Techno CMD sending error Device Error Detected: "VSCE PERM OVL NOT LOADED"
SA SPT.................................. : 1311
Head number reading..................... : Ok
ROM:
ROM version............................. : 05.ARE
ROM generation.......................... : 05.ARE
Link table version...................... : 04.AD.
Head map................................ : 0,1
Firmware version........................ : 00010000
Service area:
SA dir reading.......................... : Ok
SA Copies avalabled..................... : NONE
Configuration reading................... : No SA copy avalabled
i can read the rom, the heads doesnt knock, heads test is fine, seems like the system area is not accessible or damaged.
i would apretiate any help you can give me on this topic.
Re: wd3200aaks-00b3a0
Postby AJ2008 » 05.05.09, 12:12
Is this PCB native PCB, or donor?
ilia
Postby ilia » 05.05.09, 13:31
native
steven
Postby steven » 06.05.09, 11:01
I think your drive will detect as zero capacity... with no serial number.
I got such problem before after change head. drive Got ready no knock but No ID and No S/N... if you have Donor Drive.. perform Hotswap and see if you can access SA or not.. if Not it is head allignment issued....
ilia
Postby ilia » 06.05.09, 11:36
steven wrote:I think your drive will detect as zero capacity... with no serial number.
indeed, the only thing that the utility can detect is the drive's family. Still, it's a rather weird situation - the heads test is fine, the rom seems to be ok too, the drive doesn't knock and steel i can't get no access to the SA zone. Think that HotSwap will help?
Postby AJ2008 » 06.05.09, 12:32
I am not sure if HotSwap will help. Do you know the source of the problem? I have recieved several WD drives with simialr fault that have been dropped, and I believe this drop has damaged or modified the alignment.
ilia
Postby ilia » 06.05.09, 12:42
The client claims that the disk suffered from electirc shortage, but i cannot be sure of it
steven
Postby steven » 07.05.09, 04:55
pls let us know the progress.....
Diego
Postby Diego » 04.11.09, 14:12
Did you try to read modules by ID? I had this problems more than once, it was a firmware problem. With UDMA you can solve it.
Nova
Postby Nova » 03.12.10, 15:16
Got the same problem except mine is L9 instead of B3
Anyone know how to solve this problem?
Thank you
hassan
Postby hassan » 04.12.10, 17:52
Can you read SA Tracks except -1?
